| 914four |
Jul 12 2020, 12:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States
My alternator went out so I replaced it then took a close look at the old alternator. I found oil inside the alternator so I pulled the engine and found oil all over the inside of the fan shroud, engine tin and especially on the passenger side oil cooler area. It looked like the oil was being blown into the alternator by the fan. I had noticed a small oil leak on the bottom of the engine for the last few months. I found oil had pooled around the base of the oil pressure switch on the top of the engine so I assumed that is where the oil was leaking and was running down into the oil cooler and blown around by the fan. I spent a good deal of time cleaning the inside of the fan shroud, the engine tin, the oil cooler and the engine block. I replaced the oil pressure switch, oil cooler seals, put everything back together, re-installed the engine, checked for leaks then went for an 80 mile ride.
I got back home and, looking from the bottom of the car, found oil dripping down the same area from above the oil cooler. I pulled the engine again and the oil seemed to be coming from the top again but this time the oil switch was dry. I found pooling around the base of the 123 distributor so I pulled the distributor and replaced the very thin o-ring (that came with the 123 distributor) with a regular distributor o-ring. Thinking I found the source of the oil leak this time I cleaned everything and re-installed the engine, checked for leaks and went for short drive. Got home and found the same small amount of oil coming from the same area. This time I want to make sure I find the oil leak and fix it. I’ve done several searches and found very little information directly related to this type of oil leak. There is one thread with a similar oil leak where Clay offered some advice: http://www.914world.com/bbs2/index.php?sho...ne++Fluorescent “Replace the seal on the fan end of the crank, the oil cooler seals, the oil pressure switch, the sump plate gaskets, the drain plug washer, the pushrod tube seals, adjust the valves, and put in new valve cover gaskets. Whenever I do a clutch, I replace the flywheel end crank seal too. That about covers all the places a 914-4 can leak.” I have pulled the engine tin on the passenger side but really cannot see anything very well from the top so I’m starting to pull the engine once again. I really do want to get this oil leak fixed this time. It seems my next step may be to replace the crank seal but I sure would like to be certain this is going to be the source. From the bottom of the car I can see oil dripping down the passenger side of the engine and it seems to be coming from above the oil cooler. Do you guys have any other advice for finding an oil leak like this? Kelvin |
framos914 I'll be watching for suggestions.
I have the s... Jul 12 2020, 01:53 PM
Olympic 914 There is an oil galley plug in that area.
Jul 12 2020, 02:36 PM
914four
Where ... Jul 12 2020, 05:38 PM
type2man They sell a spray at the local auto parts for chec... Jul 12 2020, 05:46 PM
914four
They sell a spray at the local auto parts for che... Jul 13 2020, 07:59 PM
cuddy_k Have you checked the front main seal? Either a bad... Jul 12 2020, 07:16 PM
porschetub
Have you checked the front main seal? Either a ba... Jul 12 2020, 11:10 PM
ClayPerrine Kelvin,
Did you install threaded oil galley plugs... Jul 13 2020, 09:16 AM
914four
Kelvin,
Did you install threaded oil galley plug... Jul 13 2020, 08:08 PM
914four There seems to oil pooling at this oil galley.
Jul 18 2020, 04:49 PM
914four Looks like I need to replace the galley plugs with... Jul 18 2020, 04:52 PM
porschetub
Looks like I need to replace the galley plugs wit... Jul 18 2020, 07:50 PM
Porschef No, I did it with the engine assembled, just have ... Jul 18 2020, 06:55 PM
914four I really appreciate all the recommendations for fi... Aug 23 2020, 08:12 AM
ClayPerrine
I am very happy to be driving a leak-free 914 aga... Aug 23 2020, 11:44 AM
DRPHIL914
I am very happy to be driving a leak-free 914 ag... Aug 24 2020, 12:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th June 2026 - 10:37 AM |
