| ahycaramba |
Jul 12 2020, 09:44 PM
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California
It's getting HOT and summer far from over. I'm looking for alternatives to a conventional HVAC system. I like the ideal of electronically run ac and heating system that will not rob power from the engine. I was wanting to know if anyone swapped HVAC system from an electric vehicle? (IMG:style_emoticons/default/idea.gif)
Thanks in advance. |
| 914e |
Jul 13 2020, 08:48 AM
Member ![]() ![]() Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region
It's getting HOT and summer far from over. I'm looking for alternatives to a conventional HVAC system. I like the ideal of electronically run ac and heating system that will not rob power from the engine. I was wanting to know if anyone swapped HVAC system from an electric vehicle? (IMG:style_emoticons/default/idea.gif) Thanks in advance. The compressors from electric vehicles require 200 to 400 volts DC. A new 12 volt compressor can be found about $550, the down side of the low voltage is the current draw is 60 to 70 amps. You will need a high output alternator, something that can produce at least 75 amps at idle. That is typically a 150-200 amp alternator. I would install a higher amp hour battery as well at some point. |
ahycaramba Not your typical HVAC system. Jul 12 2020, 09:44 PM
hcdmueller Check out Classic Retrofit. He has a pretty impre... Jul 12 2020, 10:38 PM
Steve
Check out Classic Retrofit. He has a pretty impr... Jul 12 2020, 11:25 PM
[quote name='hcdmueller' post='2833305' date='Jul... Jul 13 2020, 05:35 AM
mgp4591 I've seen mini swamp coolers that are quite sm... Jul 12 2020, 11:53 PM
michael7810 I’ve used a B-Kool on several 914 Treks during t... Jul 13 2020, 06:54 AM
GregAmy Is that the Brit guy doing the electric A/C? He is... Jul 13 2020, 08:52 AM
brant the stock alternator is what....? 50 amps or is ... Jul 13 2020, 08:59 AM
SirAndy I like the ideal of electronically run ac and he... Jul 13 2020, 09:06 AM
73-914
I like the ideal of electronically run ac and h... Jul 14 2020, 11:54 AM
PanelBilly Or move to the PNW. High of 75’ today. Might mak... Jul 13 2020, 09:24 AM
914e
Or move to the PNW. High of 75’ today. Might ma... Jul 13 2020, 10:19 AM
914_teener
Or move to the PNW. High of 75’ today. Might m... Jul 13 2020, 03:50 PM
mepstein I just noticed an article on their site showing th... Jul 13 2020, 09:42 AM
SteveL Coolshirt Complete Club System All-In-One Kit
http... Jul 13 2020, 11:01 AM
frostyf Bit of a branch question from the main Electric to... Jul 13 2020, 05:46 PM
Steve The guys in the UK said they could put one in righ... Jul 13 2020, 05:56 PM
The guys in the UK said they could put one in rig... Jul 13 2020, 06:21 PM
frostyf Mark,
Is Johnny from the classic retrofit outfit i... Jul 13 2020, 09:32 PM
ahycaramba just incase you are wondering what I'm running... Jul 13 2020, 07:03 PM
Literati914
..; has anyone tried an alternate condensor to cu... Jul 14 2020, 11:40 AM
ClayPerrine
[quote name='frostyf' post='2833515' date='Jul 13... Jul 14 2020, 12:50 PM
Carbon-14 Not your typical HVAC system
' Swamp Coolers... Jul 14 2020, 04:01 PM
Don Contreras What options are there for A/C & heat for a 91... Jul 14 2020, 06:36 PM
Steve
What options are there for A/C & heat for a 9... Jul 15 2020, 07:17 AM
914forme :agree: used with success here in a Subaru swap @... Jul 15 2020, 08:44 AM
76-914
:agree: used with success here in a Subaru swap ... Jul 15 2020, 11:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:45 PM |
