> Car stalling AGAIN, Updates- none of them good.
rjames
post May 9 2020, 08:18 PM
I'm made of metal
Drove around for 30 minutes in 80+ degree weather. All arterial roads, so several stop lights, etc. No problems until I was almost home. Car stalled when I stopped at a light. RPMs just dropped to zero. Was able to start it again with a little difficulty and had to keep my foot on the gas to keep it from stalling out again. Power seemed ok though the rest of the way home (I think). It stalled once again at a stop light a couple of blocks from home and then again when I pulled in the driveway. I let it sit for 30 seconds, started it again and it idled just fine. Rock solid at 1000 RPMs. Pulled it into the garage where it sits now.
Prior to today the car has been running and idling perfectly since I went through the FI parts last year, which included installing a 123 distributor, new CHT sensor, a newly rebuilt mps (calibrated for correct afr on my engine), new vacuum hoses, NOS throttle body, rebuilt injectors, new fuel pump, valve adjustment and timing.
I haven’t checked the AFR since last year, not sure why it would change though.
It’s a ‘75 so the fuel pump is in the front, so I can rule out vapor lock I think.
Anyone have ideas as to why it would be stalling?
iankarr
post Jul 18 2020, 12:14 AM
When you stall, is your coil nuclear hot? Like so hot you can't keep your hand on it? If so...that could be your problem. I had that issue on my yellow car and solved it wiht a ballast resistor. Never stalled again and the coil never got hot. I know, we shouldn't need one, but...
rjames   Car stalling AGAIN   May 9 2020, 08:18 PM
timothy_nd28   What was your AFR last year?   May 10 2020, 07:04 PM
rjames   What was your AFR last year? Last setting I mad...   May 10 2020, 08:04 PM
BeatNavy   Hey Robert, 12.2 seems pretty rich at idle, IMO. ...   May 11 2020, 05:07 AM
rjames   Hey Robert, 12.2 seems pretty rich at idle, IMO....   May 11 2020, 06:49 AM
BeatNavy   Maybe lean out your ECU knob a few clicks (it has ...   May 11 2020, 06:53 AM
StarBear   Presuming it's a 1.8L (75), try the dual relay...   May 11 2020, 07:40 AM
rjames   It's a 2.0 liter. Sorry, should've clarifi...   May 11 2020, 04:21 PM
rjames   So I went to see if I could drive it around and me...   May 13 2020, 11:58 PM
dr914@autoatlanta.com   if it is a 1.8 the air flow meter flap could be st...   May 14 2020, 08:33 AM
rhodyguy   2.0 Djet. I think a 123 distr.   May 14 2020, 08:56 AM
914_teener   My quess is a kinked fuel line underneath the rack...   May 14 2020, 10:21 AM
rjames   My quess is a kinked fuel line underneath the rac...   May 14 2020, 10:56 AM
914_teener   My quess is a kinked fuel line underneath the ra...   May 14 2020, 11:47 AM
rjames   [quote name='rjames' post='2815184' date='May 14 ...   May 14 2020, 05:36 PM
Mark Henry   Vacuum leak would cause high idle. Small leak...   May 17 2020, 08:00 PM
rjames   Vacuum leak would cause high idle. Small lea...   May 17 2020, 11:25 PM
rjames   Ok, tried adjusting the MPS, but can’t keep the ...   May 16 2020, 03:13 PM
BeatNavy   Actually, I just realized that if the hose was di...   May 17 2020, 05:25 AM
rjames   Actually, I just realized that if the hose was d...   May 17 2020, 09:51 AM
rjames   Went to rebuild the MPS. I opened it up and the di...   May 17 2020, 04:12 PM
BeatNavy   I’m at a complete loss now. MPS is leaking but...   May 17 2020, 04:53 PM
Rand   I was going to ask if you listened for the fuel pu...   May 17 2020, 09:52 PM
rjames   Well...I’m perplexed. Started it up and cold, t...   May 20 2020, 12:09 AM
rjames   It’s back. Was running fine with no issues for s...   Jun 6 2020, 11:14 AM
rjames   Bumping the thread to break the silence of the cri...   Jun 10 2020, 12:59 PM
cuddy_k   I know you changed the relay board, but did you ch...   Jun 10 2020, 09:00 PM
rjames   I know you changed the relay board, but did you c...   Jun 10 2020, 11:38 PM
mepstein   Fuel filter or tank screen?   Jun 11 2020, 04:21 AM
rjames   Fuel filter or tank screen? Replaced the filter...   Jun 11 2020, 06:00 PM
bzettner   I read thru this yesterday but can't remember ...   Jun 11 2020, 07:43 PM
rjames   I read thru this yesterday but can't remember...   Jun 12 2020, 10:11 AM
BeatNavy   I read thru this yesterday but can't remembe...   Jun 12 2020, 10:24 AM
JOEPROPER   Your critical inputs are your MPS (which You'v...   Jun 12 2020, 06:41 AM
DRPHIL914   I read thru this yesterday but can't remember...   Jun 12 2020, 12:51 PM
rjames   Ugh. Well today I eliminated the following 3 thing...   Jun 18 2020, 10:18 PM
914_teener   Think about this. A loose connector or bad wire cr...   Jun 19 2020, 12:23 AM
rjames   Think about this. A loose connector or bad wire c...   Jun 19 2020, 12:33 AM
BeatNavy   That sucks, Robert. Sorry about the frustration. ...   Jun 19 2020, 05:05 AM
rjames   That sucks, Robert. Sorry about the frustration....   Jun 19 2020, 12:40 PM
JOEPROPER   The only other thing I can think of is the old ign...   Jun 19 2020, 09:27 AM
BeatNavy   No problem, Robert. Boy I hope that wiring harness...   Jun 19 2020, 01:22 PM
logica   I have similar symptoms in my '74 2.0 EFI. Th...   Jul 15 2020, 11:55 PM
bgconsul   I have similar symptoms in my '74 2.0 EFI. T...   Jul 16 2020, 10:42 AM
rjames   Since I started this post, I'll give an update...   Jul 16 2020, 12:13 PM
second wind   I have to share my recent experience as I include ...   Jul 16 2020, 12:38 PM
rjames   So I was able to drive around for an hour last nig...   Jul 16 2020, 01:05 PM
914_teener   So I was able to drive around for an hour last ni...   Jul 17 2020, 04:52 PM
yellowporky   maybe i missed it but have you tested the electric...   Jul 16 2020, 01:47 PM
rjames   maybe i missed it but have you tested the electri...   Jul 16 2020, 01:52 PM
yellowporky   have you tested either of MPS electronics? Vacuum ...   Jul 16 2020, 07:55 PM
rjames   have you tested either of MPS electronics? Vacuum...   Jul 17 2020, 11:07 AM
BeatNavy   Robert I have a new-ish FI wiring harness and 043 ...   Jul 17 2020, 02:30 PM
rjames   Robert I have a new-ish FI wiring harness and 043...   Jul 17 2020, 11:54 PM
Rand   Godspeed Robert. This is definitely one we need to...   Jul 18 2020, 12:00 AM
rjames   Godspeed Robert. This is definitely one we need t...   Jul 18 2020, 10:24 AM
cuddy_k   When you stall, is your coil nuclear hot? Like so ...   Jul 18 2020, 12:14 AM
rjames   When you stall, is your coil nuclear hot? Like so...   Jul 18 2020, 10:23 AM
rjames   Update to the ongoing saga..apologies in advance f...   Jul 22 2020, 01:24 PM
rjames   Bump out of desperation. Should I feel a fair am...   Jul 25 2020, 02:07 PM
BeatNavy   Can you be more specific about where air is coming...   Jul 25 2020, 02:11 PM
rjames   Can you be more specific about where air is comin...   Jul 25 2020, 02:45 PM
toadman   [quote name='BeatNavy' post='2837048' date='Jul 2...   Jul 26 2020, 06:34 PM
yellowporky   Did you ever rule out the ecu?   Jul 25 2020, 03:17 PM
rjames   Did you ever rule out the ecu? I did   Jul 25 2020, 04:01 PM
yellowporky   If all of your components check out, replaced your...   Jul 26 2020, 11:06 AM
rjames   If all of your components check out, replaced you...   Jul 26 2020, 03:23 PM
yellowporky   if he replaced his fuel injection harness the grou...   Jul 26 2020, 06:46 PM
rjames   if he replaced his fuel injection harness the gro...   Jul 26 2020, 08:38 PM
rjames   Compression #s with engine warm, all plugs removed...   Jul 27 2020, 10:26 PM
euro911   Compression #s with engine warm, all plugs removed...   Nov 6 2020, 02:02 PM
rjames   Compression #s with engine warm, all plugs remove...   Nov 6 2020, 06:12 PM
rjames   Just wanted to dust the cobwebs off of this thread...   Aug 24 2020, 11:37 AM
BeatNavy   Just wanted to dust the cobwebs off of this threa...   Aug 24 2020, 03:02 PM
rjames   So I'll give you two :Qarl: :Qarl: and one ...   Aug 24 2020, 03:19 PM
orthobiz   Thanks rj for helping me to think about my 1974 2....   Aug 24 2020, 04:32 PM
rjames   Ok I'm back to updating my thread that seeming...   Nov 3 2020, 05:04 PM
porschetub   Ok I'm back to updating my thread that seemin...   Nov 3 2020, 06:33 PM
rjames   Yes, engine was warm when I checked the compressio...   Nov 3 2020, 06:39 PM
rhodyguy   A local member had the same 'hunting' (flu...   Nov 4 2020, 07:54 AM
rjames   A local member had the same 'hunting' (fl...   Nov 4 2020, 10:36 AM
Highland   I know this theory may be completely invalid, but ...   Nov 4 2020, 09:35 AM
yellowporky   Did you ever replace the board on your TPS? 914 ru...   Nov 4 2020, 12:28 PM
rjames   Did you ever replace the board on your TPS? 914 r...   Nov 4 2020, 01:21 PM
Highland   Did you ever replace the board on your TPS? 914 ...   Nov 4 2020, 05:19 PM
rjames   [quote name='rjames' post='2864365' date='Nov 4 2...   Nov 4 2020, 05:55 PM
second wind   Something about the idle changing with amount of r...   Nov 4 2020, 01:23 PM
rjames   Something about the idle changing with amount of ...   Nov 4 2020, 02:09 PM
rudedude   Have you taken the tri-ground and actually taken ...   Nov 4 2020, 06:33 PM
yellowporky   It seems like 2 different things happening here. ...   Nov 4 2020, 08:31 PM
rjames   All vacuum hoses are new and have zip ties on th...   Nov 4 2020, 10:47 PM
BeatNavy   Robert, sorry this issue has resurfaced :( It...   Nov 5 2020, 06:13 AM
rjames   Robert, sorry this issue has resurfaced :) It...   Nov 5 2020, 11:52 AM
904svo   Just a WAG , check the ground strap from the trans...   Nov 5 2020, 12:31 PM
rjames   Just a WAG , check the ground strap from the tran...   Nov 5 2020, 02:00 PM
yellowporky   Not sure it is possible to cause a stall but is yo...   Nov 6 2020, 09:13 AM
rjames   Not sure it is possible to cause a stall but is y...   Nov 6 2020, 11:31 AM
yellowporky   So when the car is warm it idles down and stalls? ...   Nov 6 2020, 12:58 PM
rjames   So when the car is warm it idles down and stalls?...   Nov 6 2020, 01:46 PM
bzettner   I'm on pins and needles! What is the late...   May 16 2021, 01:14 PM
- Lo-Fi Version Time is now: 8th July 2025 - 09:18 PM
