Battery cut off switches, Wiring |
CG-914 |
Jun 2 2020, 02:30 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I want to instal original Bosch cut off switches, like on the original 914GT. One on the tunnel and one under the windshield driver side.
Does anybody have directions for the wiring? Do you run from the battery all the way up front and back to the starter? |
windforfun |
Jul 19 2020, 06:25 PM
Senior Member Group: Members Posts: 1,835 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
This is excellent input. Smart, smart, & smart. From an EE perspective, I would keep it to one switch with short wiring (no pun intended). You have to run the battery cables like you suggested. I suppose a relay might work if it can handle the current. Can the coil be switched off instead?
Lo-Fi Version | Time is now: 8th June 2024 - 05:25 PM |
