Front Sways |
Front Sways |
Teknon |
Dec 17 2004, 01:22 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
OK, the new triangle piece that you have to buy, if your car never had sways, is shown installed w/one point of the triangle pointing straight down. Thus, the reason for grinding out the sheet metal, inside the car, to accommodate the triangle.
Shown in Figure 6 on this link..... www.pelicanparts.com/techarticles/914_front_swaybar/914_front_swaybar.htm Why can't you just lay down the triangle with the point up instead? Then, you don't have to cut any thing. Looks to me the cut hole for the bar is in the same exact place. Would there be any problem doing it like that? \ (IMG:style_emoticons/default/chatsmiley.gif) |
Engman |
Dec 17 2004, 02:28 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Put mine on the 73. If you want to do it right the bird article is correct. If you flip them and put the point up you will have to grind a bunch off the bottom edge of the triangle piece to put the center hole in the correct spot. This will weaken the support gigen by the inner triangle mount. ---- It is your car, your choice. But this will not have the same support as the factory ones.......
M |
Lo-Fi Version | Time is now: 8th June 2024 - 01:38 AM |
