| PanelBilly |
Oct 29 2018, 12:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
| Aualexa1 |
Jul 23 2020, 05:24 PM
Newbie ![]() Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region |
I’ve got a ‘73 1.7 L and recently picked up a Mainley oil temp dip stick. Is it supposed to fit snugly when inserted? Unlike my originally dip stick, it seems to just sit in the tube and can be removed without any resistance.
| Craigers17 |
Jul 23 2020, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 880 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States
I’ve got a ‘73 1.7 L and recently picked up a Mainley oil temp dip stick. Is it supposed to fit snugly when inserted? Unlike my originally dip stick, it seems to just sit in the tube and can be removed without any resistance. Can you let us know where you purchased yours from and if they have any left. I purchased a Mainely unit about 2 months ago from Precision Matters, and the owner said it was his last one. Unfortunately, upon the first insertion, when I pulled it straight out(no twisting, etc. the rubber grommet came loose. I could have super glued it and made it work, but in addition the needle was all over the place and was definitely not functioning correctly. Long story short, I sent it back, and Precision Matters fully refunded my money. I would love to find another one just to verify the temps that my gauge is showing. |
| Aualexa1 |
Jul 23 2020, 05:56 PM
I picked mine up from the classifieds. Did yours fit securely or was it just resting in the tube? I guess my question is: Is the rubber grommet supposed to help hold it in place and seal the tube?
Edit: answering my own question. I took the rubber grommet off the dip stick and was able to snap the grommet onto the tube that the dip stick fits in. The Mainley dip stick then slides in through the grommet. It still not held in super tight, but is much more secure. |
| Craigers17 |
Jul 23 2020, 06:10 PM
I picked mine up from the classifieds. Did yours fit securely or was it just resting in the tube? I guess my question is: Is the rubber grommet supposed to help hold it in place and seal the tube? I will defer to those who have used theirs successfully, but, like you, it seemed to just rest on top of the tube. I figured that the grommet was supposed to be pushed into the tube at least slightly(EDIT...as you stated, it might have slipped around the tube.) to create the seal. In my case that seemed to work, but when I tried to pull it out, that's when the grommet came loose. In the instructions, it says specifically to NOT twist it, which I did not, but even so, it separated. As I stated earlier, that wasn't the deal breaker...I could have glued it back in place, but mine simply was not functioning correctly. |
PanelBilly Dipstick Temp Gauge Oct 29 2018, 12:29 PM
GregAmy http://www.mainelycustombydesign.com/
I seem to r... Oct 29 2018, 12:40 PM
jim_hoyland I was hoping 914Rubber might make these again; the... Oct 29 2018, 12:52 PM
jim_hoyland Originsal face size: Oct 29 2018, 12:54 PM
jim_hoyland Preferred size:
@Mikey914 Oct 29 2018, 12:55 PM
PanelBilly This is for my 3.0 so I need something that will g... Oct 29 2018, 01:09 PM
GregAmy
This is for my 3.0 so I need something that will ... Oct 29 2018, 01:26 PM
porschetub
This is for my 3.0 so I need something that will ... Jul 23 2020, 07:23 PM
IronHillRestorations
This is for my 3.0 so I need something that will ... Jul 24 2020, 05:49 AM
Ferg I don't think the temp of the oil in the tank ... Oct 29 2018, 01:43 PM
dr914@autoatlanta.com I think that VDO still makes one
I recall readi... Oct 29 2018, 04:08 PM
mb911 For a -6 the tank could be modified for a temp sen... Oct 29 2018, 04:48 PM
SO.O.C914er I would absolutely buy one. I looked for this abou... Oct 29 2018, 06:05 PM
wndsrfr Here's an angle to try....food temperature pro... Oct 29 2018, 06:45 PM
Valy @panelbilly
I have a dipstick one from the last r... Oct 29 2018, 07:38 PM
Rob-O
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 29 2018, 08:50 PM
Valy
[b]@[url=http://www.914world.com/bbs2/index.php?... Oct 29 2018, 09:43 PM
Rob-O Could happen a few ways. But probably most common... Oct 30 2018, 05:33 AM
rmdinmd
[b]@[url=http://www.914world.com/bbs2/index.php?... Oct 30 2018, 06:17 AM
dcheek Mainely was bought by Precision Matters.
They sti... Oct 30 2018, 07:21 AM
VaccaRabite If you can get one of the Mainely units get one. ... Oct 30 2018, 09:31 AM
GregAmy Ditto. It originally allowed me to verify my oil t... Oct 30 2018, 11:34 AM
jim_hoyland I was hoping 914 Rubber would make these; a critic... Jul 23 2020, 06:28 PM
PanelBilly Have a gauge but it doesn't have numbers on it... Jul 23 2020, 07:37 PM
Mikey914 I initially did some research on this and a lot of... Jul 23 2020, 11:47 PM
jim_hoyland
I initially did some research on this and a lot o... Jul 24 2020, 05:00 AM
Frankvw a dipstick temp device was for the type1 (beetle) ... Jul 24 2020, 04:25 AM
GregAmy I'd be interested in a replacement. I managed ... Jul 24 2020, 07:22 AM
jim_hoyland
I'd be interested in a replacement. I managed... Jul 24 2020, 09:01 AM
djotron @Mikey914 - Following up to see if there is any u... Jan 1 2023, 09:09 PM
Mikey914 Yes, Just haven't been able to do much over th... Jan 2 2023, 02:56 AM
second wind
Yes, Just haven't been able to do much over t... Jan 2 2023, 02:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 10:51 AM |
