Front Sways |
Front Sways |
Teknon |
Dec 17 2004, 01:22 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
OK, the new triangle piece that you have to buy, if your car never had sways, is shown installed w/one point of the triangle pointing straight down. Thus, the reason for grinding out the sheet metal, inside the car, to accommodate the triangle.
Shown in Figure 6 on this link..... www.pelicanparts.com/techarticles/914_front_swaybar/914_front_swaybar.htm Why can't you just lay down the triangle with the point up instead? Then, you don't have to cut any thing. Looks to me the cut hole for the bar is in the same exact place. Would there be any problem doing it like that? \ (IMG:style_emoticons/default/chatsmiley.gif) |
Jeff Bonanno |
Dec 17 2004, 05:57 PM
il dottore Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 |
Sorry Joe - i wasn't trying to offend you. i don't claim to be an 'authority'. i was simply offering what i believe to be sound advice. it sounds like you have made up your mind on how you want to do it so go ahead. i do agree with Engman that there should be no gap in the fitment and with Mike that the bar will be a tight fit with the tank if the vertical height goes north of stock.
jbb ps i do drive to work the same way each day and avoid trucks with trailer hitches |
Lo-Fi Version | Time is now: 7th June 2024 - 08:45 AM |
