| MrPurdy |
Jul 27 2020, 09:00 AM
Newbie ![]() Group: Members Posts: 1 Joined: 27-July 20 From: Oceanside, CA Member No.: 24,541 Region Association: Southern California |
Hello,
I recently bought a 1973 Porsche 914 with a 1.7 and fuel injection. The car ran ok when first purchased, However, I went to start the car, it would not fire up. Got spark etc, but no fuel. I noticed most of the fuel injection wiring harness is brittle and or have cracked wires. I have tried cutting out the old wiring where I can, however to no such luck.I would like to keep the car fuel injected, however, I can't find where to buy a new wiring harness and or don't want to assume that is the only cause. I recently have been discussing with other past owners of the 914 and two have said to go with Dual Weber 44's or 48's? if I went this route, do I need to change out my distributor and Cam? I know the fuel pump will need to be replaced. I would like some input and or advise from someone who may have already traded out the fuel injection for carbs. Lastly, Im an old VW guy and know carbs but the wiring on this fuel injection seems it could take me down the rabbit hole to more problems and cost. Thanks Mark |
| thelogo |
Jul 27 2020, 01:20 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Hello, I recently bought a 1973 Porsche 914 with a 1.7 and fuel injection. The car ran ok when first purchased, However, I went to start the car, it would not fire up. Got spark etc, but no fuel. I noticed most of the fuel injection wiring harness is brittle and or have cracked wires. I have tried cutting out the old wiring where I can, however to no such luck.I would like to keep the car fuel injected, however, I can't find where to buy a new wiring harness and or don't want to assume that is the only cause. I recently have been discussing with other past owners of the 914 and two have said to go with Dual Weber 44's or 48's? if I went this route, do I need to change out my distributor and Cam? I know the fuel pump will need to be replaced. I would like some input and or advise from someone who may have already traded out the fuel injection for carbs. Lastly, Im an old VW guy and know carbs but the wiring on this fuel injection seems it could take me down the rabbit hole to more problems and cost. Thanks Mark 1st off i love carbs but ... Youre at a crossroads, ive been there before You cant just go to carbs . unless you use a set of baby single throat webbers . those bolt right on and while not perfect .not bad . my opinion also need fuel pump But to really do carbs . 40s and up you have to rebuild the engine to take advantage . plain and simple You could do djet . but 1st find a witch doctor to help . And its no longer reliable because its fuckin ancient Not because its not a great system . So if you can afford . build a killer carb engine . If not the others will be more budget friendly but not as spunky. I would put baby webbers on my 1.7 in a second ( djet also starting giving up) but i lucked my way into a big /4 So thats what i would do |
MrPurdy should I junk my fuel injection for my 1.7 for dual 44idf Webers Jul 27 2020, 09:00 AM
KELTY360 :wttc:
:popcorn: Jul 27 2020, 09:18 AM
nditiz1 From someone who loves running carbs this is what ... Jul 27 2020, 09:26 AM
Frankvw I also have a 1973 1.7 ... and I also come from th... Jul 27 2020, 09:32 AM
Root_Werks I would keep the FI if possible. Jul 27 2020, 10:08 AM
ClayPerrine :agree:
The stock cam in a 914 is not good with ... Jul 27 2020, 10:18 AM
brant wrong cam (requires rebuilding the motor)
wrong di... Jul 27 2020, 10:28 AM
914sgofast2 If you go to carbs, you will lose horsepower unles... Jul 27 2020, 10:29 AM
914Sixer Just say NO to carbs! Jul 27 2020, 11:42 AM
windforfun No. KISS. Jul 27 2020, 12:00 PM
JeffBowlsby Here is my website if you decide to keep the FI.
... Jul 27 2020, 02:58 PM
porschetub :agree: with all comments,end of the day by the ti... Jul 27 2020, 04:04 PM
jdamiano 44s are to big you would run rich no matter how yo... Jul 27 2020, 04:14 PM
rgolia Totally agree with all the comments. When I switc... Jul 27 2020, 04:28 PM
ctc911ctc I was there once upon a time, I stuck with FI and ... Jul 27 2020, 04:28 PM
thelogo it is a stock car with dozens of experts.
CTC911... Jul 27 2020, 08:22 PM
ClayPerrine
CTC91... Jul 28 2020, 06:51 AM
Superhawk996
Carbs are like doing accounting with a pencil an... Jul 28 2020, 09:40 AM
saigon71 I'm not at all anti-carb...but:
Since your st... Jul 28 2020, 05:55 AM
76-914 Better yet put a Subaru in it. :stir: :D Jul 28 2020, 07:00 AM
Tdskip Welcome Mark! Lots of us here in SoCal.
Troub... Jul 28 2020, 07:21 AM
dr914@autoatlanta.com not in a million years. PLUS 44s are for racing o... Jul 28 2020, 08:34 AM
Bleyseng My $.02 worth...
I bought my car in 1995 with... Jul 28 2020, 08:57 AM
Root_Werks I think there's a component of keeping any old... Jul 28 2020, 09:43 AM
Ansbacher Difference between FI and Carbs:
When FI breaks y... Jul 28 2020, 10:22 AM
thelogo
When FI breaks ... Jul 28 2020, 01:20 PM
ClayPerrine
When FI breaks... Jul 28 2020, 02:19 PM
ClayPerrine
When FI breaks ... Jul 28 2020, 02:18 PM
Rav914 I love opinion pieces.
I went from a functioning ... Jul 28 2020, 10:42 AM
Jakester1 I had the same problem with my '71. The 4 whit... Jul 28 2020, 11:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:27 AM |
