Flywheel minimum thickness? |
Cazz |
Dec 6 2017, 03:03 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
My flywheel is grooved and needs to be machined.
-Does anyone know the minimum thickness of the flywheel surface where the clutch disc mates? -the thickness I get using my cheap calipers is 4mm thickness on the face. -what is the minimum thickness after a machine shop cuts the face? |
ctc911ctc |
Jul 30 2020, 07:51 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74, 2.0 22K miles All, 1st and 2nd sync rings were bugging me so I removed the tranny. While waiting for the gear parts (dogteeth, etc.) i took a look at the clutch. Though it was good I thought I would replace it since it was 40+ years old. (IMG:style_emoticons/default/idea.gif) I have a new clutch, pressure plate, and throw-out bearing. I think the Flywheel is in great shape. No burn marks or grooves - just minimum wear. (IMG:style_emoticons/default/shades.gif) I watched the installation video on youtube and was a bit through by crankshaft play. Do I need to recalibrate the shims for this rebuild if I DO NOT replace the flywheel? (IMG:style_emoticons/default/confused24.gif) Thank you Teeners CTC911CTC |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:36 AM |
