| AndrewBlyholder |
Jul 31 2020, 04:55 PM
Member ![]() ![]() Group: Members Posts: 112 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
Dropped the motor on my street car for hell hole rust repairs. As long as I had the motor out, thought I'd fix a few oil leaks, which I thought were mostly old push rod tube seals having given out. Just discovered the bolt that holds the oil pickup tube is stripped. That will definitely be a leaker too. The real fix for this is to of course split the case and heli-coil the stripped threads. Really didn't want to go there. Does anyone have any suggestions for a fix for this that DOESN'T include splitting the case?
Any suggestions would be appreciated. Thanks, Andrew B. |
| Krieger |
Aug 1 2020, 10:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,878 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Just to be clear. Is this threads on the stud that holds the sump plate cover on? I would consider using red locktite, but you may not be able to get enough torque on it. What about using the next size down metric or standard die and make some new threads?
AndrewBlyholder Urgent question - stripped oil pickup bolt Jul 31 2020, 04:55 PM
914sgofast2
Dropped the motor on my street car for hell hole ... Jul 31 2020, 09:23 PM
914Sixer 1st up try putting a new bolt in. 2nd shot is new... Aug 1 2020, 09:26 AM
Jake Raby Unless it has "syndrome" you can use a l... Aug 1 2020, 06:25 PM
AndrewBlyholder Thanks for the suggestions.
Tried a longer bolt b... Aug 9 2020, 04:07 PM
Tonyooc You can try a heli coil. Aug 9 2020, 04:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st August 2026 - 04:14 AM |
