| ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,384 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
| pilothyer |
Aug 1 2020, 03:32 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you heat it up with a MAPP torch with it under that much pressure it will probably jump right off.
| ctc911ctc |
Aug 1 2020, 03:46 PM
ctc911ctc How much torque is too much? Aug 1 2020, 02:08 PM
Superhawk996 Heat.
A rap on the side of the hub while it's... Aug 1 2020, 02:18 PM
ctc911ctc Super Hawk to the rescue!
Heat and hammer... Aug 1 2020, 02:23 PM
ctc911ctc Lots of heat and hammer, no joy yet,,,, over night... Aug 1 2020, 03:21 PM
Ahhhhh
I only have a propane torch,,,,,, will ke... Aug 1 2020, 04:19 PM
Superhawk996
Ahhhhh
I only have a propane torch,,,,,, will ke... Aug 1 2020, 04:41 PM
porschetub No ,penetrating oil will have no effect on a taper... Aug 1 2020, 04:58 PM
porschetub X2 reply sorry. Aug 1 2020, 05:02 PM
Jake Raby These can be tough. They are also getting rare to ... Aug 1 2020, 06:22 PM
ctc911ctc Is this the right setup for high and fast heat?
h... Aug 1 2020, 06:53 PM
73-914
... Aug 1 2020, 07:15 PM
ctc911ctc Yikes, I was thinking that I was pulling too hard ... Aug 1 2020, 06:54 PM
cuddy_k :agree: with the mapp torch. Two things...
1) whe... Aug 1 2020, 07:13 PM
76-914 You don't need to buy a torch, just a bottle o... Aug 1 2020, 07:16 PM
bretth I have not done this yet myself, but when hitting ... Aug 2 2020, 12:15 AM
Frankvw I also had the same issue on my type4 2.0L bus eng... Aug 2 2020, 07:32 AM
ctc911ctc Buying MAPP gas now, I do not need O2 as in the pi... Aug 2 2020, 07:41 AM
Superhawk996
Buying MAPP gas now, I do not need O2 as in the p... Aug 2 2020, 08:42 AM
ctc911ctc Hit it with the mapp torch for 60 sec, hammered ar... Aug 2 2020, 09:00 AM
sixnotfour Is the puller going through the bore of the flange... Aug 2 2020, 09:35 AM
ctc911ctc I have 6 pullers of various size, this puller has ... Aug 2 2020, 11:12 AM
sixnotfour
I have 6 pullers of various size, this puller has... Aug 2 2020, 11:18 AM
Superhawk996 Yowza -- can see deformation of the hub from the h... Aug 2 2020, 10:18 AM
ctc911ctc OK, more heat - less hammer!
BTW, the marks t... Aug 2 2020, 11:16 AM
sixnotfour https://www.youtube.com/watch?v=DZU_-BLDNAU
DZU_-... Aug 2 2020, 10:43 AM
cuddy_k At least 5 minutes I would say, but @superhawk996... Aug 2 2020, 10:56 AM
cuddy_k double post Aug 2 2020, 10:56 AM
Superhawk996 :D
Like the video and special tool. The princip... Aug 2 2020, 10:57 AM
sixnotfour I shouldn't even respond ..but..my motto.. typ... Aug 2 2020, 11:02 AM
Superhawk996
I shouldn't even respond ..but..my motto.. ty... Aug 2 2020, 11:11 AM
bobboinski I have been successful doing this by getting the p... Aug 2 2020, 11:31 AM
bobboinski I just looked back at your puller. I use a steerin... Aug 2 2020, 11:40 AM
ctc911ctc :shoot2kill: HEAT, MORE HEAT :shoot2kill:
W... Aug 2 2020, 03:38 PM
porschetub
... Aug 2 2020, 05:38 PM
Superhawk996
Well it came off,
:Qarl: :cheer: Aug 3 2020, 06:29 AM
bobboinski :beer2: No opinion on the plugs, I cleaned mine u... Aug 2 2020, 05:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th October 2026 - 02:13 PM |
