| jaredmcginness |
Jul 4 2020, 10:03 AM
... ![]() ![]() ![]() Group: Members Posts: 510 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
See update and actual numbers on the added reply.
Sorry for the novel!! Hey guys, I'm building a 1911. I want to make sure that I have my thoughts in the right place. -96 Bore x 66 stroke. Fresh rebuilt 1.7 heads with a 105mm fly cut register. Stock valves -Running a .495 lift cam, lifters to match, HD springs + counter bore .630 (IIRC) extended. I need to CC my heads first, get the volume, then determine my deck height and compression ratio? Stock 1.7 heads are 50cc. I assume mine will end up a tad larger, maybe 52cc. (will the fly cut alter the size?) But I might be off. Is 8.5:1 a good target ratio? Ive read a few threads and this seems to be the middle ground compression. A good target DH is .045-.065? With a minimum of 0.040 to avoid contact. A few examples - per a CR calculator: 50cc, 0.065 = 8.7:1 50cc, 0.045 = 9.2:1 53cc, 0.065 = 8.4:1 53cc, 0.045 = 8.8:1 This in mind, depending on my head volume it should be easy to narrow down where I need to be. Am I on the right track? New to this and been digging into some old books. Whats a good compression ratio, that should be safe for a mild carbed (dual 36) motor and mild cam. Want this thing to last more than a summer! I dont really have a target CR, because I dont know the difference of a few decimal points! Happy 4th (IMG:style_emoticons/default/beerchug.gif) ! |
| nditiz1 |
Aug 1 2020, 10:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
Mine were AA as well with my 2056 rebuild. Milled .014 I believe.
jaredmcginness Thinking out loud - 1911 Jul 4 2020, 10:03 AM
jaredmcginness Hey guys,
To update this, I just CC’d my heads ... Aug 1 2020, 08:33 AM
nditiz1 I calculated 8.5:1 via CB performances website. O... Aug 1 2020, 09:44 AM
Al Meredith Will someone with more knowledge than I please exp... Aug 1 2020, 10:21 AM
Superhawk996 Generally speaking you're going to end up with... Aug 1 2020, 10:57 AM
jaredmcginness Thank you for the fantastic response @superhawk99... Aug 1 2020, 11:58 AM
Superhawk996
For clarity, if I port and polish, that will mak... Aug 1 2020, 12:06 PM
nditiz1 I want to say when I was calculating DH on my 2056... Aug 1 2020, 11:58 AM
Superhawk996
I want to say when I was calculating DH on my 205... Aug 1 2020, 12:08 PM
jaredmcginness
I want to say when I was calculating DH on my 20... Aug 1 2020, 12:20 PM
Superhawk996
[quote name='Superhawk996' post='2838928' date='A... Aug 1 2020, 01:38 PM
VaccaRabite A 9:1 CR will give you more power, but also more h... Aug 1 2020, 03:57 PM
jaredmcginness Thanks a lot everyone.
I’m expecting to have d... Aug 1 2020, 04:54 PM
cuddy_k What brand of P&C are you using? The reason I ... Aug 1 2020, 07:30 PM
jaredmcginness
What brand of P&C are you using? The reason I... Aug 1 2020, 08:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 11:51 PM |
