| ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,384 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
| sixnotfour |
Aug 2 2020, 09:35 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,379 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Is the puller going through the bore of the flange ?? Looks to big in diameter to go through....put the bolt in it and back off a couple turns , and push on the head , with puller..
| ctc911ctc |
Aug 2 2020, 11:12 AM
I have 6 pullers of various size, this puller has the bolt part that fits perfectly within the shaft (without touching the threads) and has the arms off of the smallest puller so they fit on the ears of the yoke.
Thank you! Is the puller going through the bore of the flange ?? Looks to big in diameter to go through....put the bolt in it and back off a couple turns , and push on the head , with puller.. |
ctc911ctc How much torque is too much? Aug 1 2020, 02:08 PM
Superhawk996 Heat.
A rap on the side of the hub while it's... Aug 1 2020, 02:18 PM
ctc911ctc Super Hawk to the rescue!
Heat and hammer... Aug 1 2020, 02:23 PM
ctc911ctc Lots of heat and hammer, no joy yet,,,, over night... Aug 1 2020, 03:21 PM
pilothyer If you heat it up with a MAPP torch with it under ... Aug 1 2020, 03:32 PM
ctc911ctc Ahhhhh
I only have a propane torch,,,,,, will kee... Aug 1 2020, 03:46 PM
Ahhhhh
I only have a propane torch,,,,,, will ke... Aug 1 2020, 04:19 PM
Superhawk996
Ahhhhh
I only have a propane torch,,,,,, will ke... Aug 1 2020, 04:41 PM
porschetub No ,penetrating oil will have no effect on a taper... Aug 1 2020, 04:58 PM
porschetub X2 reply sorry. Aug 1 2020, 05:02 PM
Jake Raby These can be tough. They are also getting rare to ... Aug 1 2020, 06:22 PM
ctc911ctc Is this the right setup for high and fast heat?
h... Aug 1 2020, 06:53 PM
73-914
... Aug 1 2020, 07:15 PM
ctc911ctc Yikes, I was thinking that I was pulling too hard ... Aug 1 2020, 06:54 PM
cuddy_k :agree: with the mapp torch. Two things...
1) whe... Aug 1 2020, 07:13 PM
76-914 You don't need to buy a torch, just a bottle o... Aug 1 2020, 07:16 PM
bretth I have not done this yet myself, but when hitting ... Aug 2 2020, 12:15 AM
Frankvw I also had the same issue on my type4 2.0L bus eng... Aug 2 2020, 07:32 AM
ctc911ctc Buying MAPP gas now, I do not need O2 as in the pi... Aug 2 2020, 07:41 AM
Superhawk996
Buying MAPP gas now, I do not need O2 as in the p... Aug 2 2020, 08:42 AM
ctc911ctc Hit it with the mapp torch for 60 sec, hammered ar... Aug 2 2020, 09:00 AM
sixnotfour
I have 6 pullers of various size, this puller has... Aug 2 2020, 11:18 AM
Superhawk996 Yowza -- can see deformation of the hub from the h... Aug 2 2020, 10:18 AM
ctc911ctc OK, more heat - less hammer!
BTW, the marks t... Aug 2 2020, 11:16 AM
sixnotfour https://www.youtube.com/watch?v=DZU_-BLDNAU
DZU_-... Aug 2 2020, 10:43 AM
cuddy_k At least 5 minutes I would say, but @superhawk996... Aug 2 2020, 10:56 AM
cuddy_k double post Aug 2 2020, 10:56 AM
Superhawk996 :D
Like the video and special tool. The princip... Aug 2 2020, 10:57 AM
sixnotfour I shouldn't even respond ..but..my motto.. typ... Aug 2 2020, 11:02 AM
Superhawk996
I shouldn't even respond ..but..my motto.. ty... Aug 2 2020, 11:11 AM
bobboinski I have been successful doing this by getting the p... Aug 2 2020, 11:31 AM
bobboinski I just looked back at your puller. I use a steerin... Aug 2 2020, 11:40 AM
ctc911ctc :shoot2kill: HEAT, MORE HEAT :shoot2kill:
W... Aug 2 2020, 03:38 PM
porschetub
... Aug 2 2020, 05:38 PM
Superhawk996
Well it came off,
:Qarl: :cheer: Aug 3 2020, 06:29 AM
bobboinski :beer2: No opinion on the plugs, I cleaned mine u... Aug 2 2020, 05:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th October 2026 - 02:14 PM |
