> How much torque is too much?, Removing fan yoke
ctc911ctc
post Aug 1 2020, 02:08 PM
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear)
I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,,
I am using penetrating oil on the shaft,,,,,,,,,what next?
Heat?
Incantations?
Ideas?
bobboinski
post Aug 2 2020, 05:02 PM
(IMG:style_emoticons/default/beerchug.gif) No opinion on the plugs, I cleaned mine up and gave them a coat of JB Weld for insurance as they didn't seem to be leaking. Not a proper repair, I know.
ctc911ctc   How much torque is too much?   Aug 1 2020, 02:08 PM
Superhawk996   Heat. A rap on the side of the hub while it's...   Aug 1 2020, 02:18 PM
ctc911ctc   Super Hawk to the rescue! Heat and hammer...   Aug 1 2020, 02:23 PM
ctc911ctc   Lots of heat and hammer, no joy yet,,,, over night...   Aug 1 2020, 03:21 PM
pilothyer   If you heat it up with a MAPP torch with it under ...   Aug 1 2020, 03:32 PM
ctc911ctc   Ahhhhh I only have a propane torch,,,,,, will kee...   Aug 1 2020, 03:46 PM
mepstein   Ahhhhh I only have a propane torch,,,,,, will ke...   Aug 1 2020, 04:19 PM
Superhawk996   Ahhhhh I only have a propane torch,,,,,, will ke...   Aug 1 2020, 04:41 PM
porschetub   No ,penetrating oil will have no effect on a taper...   Aug 1 2020, 04:58 PM
porschetub   X2 reply sorry.   Aug 1 2020, 05:02 PM
Jake Raby   These can be tough. They are also getting rare to ...   Aug 1 2020, 06:22 PM
ctc911ctc   Is this the right setup for high and fast heat? h...   Aug 1 2020, 06:53 PM
73-914   Is this the right setup for high and fast heat? ...   Aug 1 2020, 07:15 PM
ctc911ctc   Yikes, I was thinking that I was pulling too hard ...   Aug 1 2020, 06:54 PM
cuddy_k   :agree: with the mapp torch. Two things... 1) whe...   Aug 1 2020, 07:13 PM
76-914   You don't need to buy a torch, just a bottle o...   Aug 1 2020, 07:16 PM
bretth   I have not done this yet myself, but when hitting ...   Aug 2 2020, 12:15 AM
Frankvw   I also had the same issue on my type4 2.0L bus eng...   Aug 2 2020, 07:32 AM
ctc911ctc   Buying MAPP gas now, I do not need O2 as in the pi...   Aug 2 2020, 07:41 AM
Superhawk996   Buying MAPP gas now, I do not need O2 as in the p...   Aug 2 2020, 08:42 AM
ctc911ctc   Hit it with the mapp torch for 60 sec, hammered ar...   Aug 2 2020, 09:00 AM
sixnotfour   Is the puller going through the bore of the flange...   Aug 2 2020, 09:35 AM
ctc911ctc   I have 6 pullers of various size, this puller has ...   Aug 2 2020, 11:12 AM
sixnotfour   I have 6 pullers of various size, this puller has...   Aug 2 2020, 11:18 AM
Superhawk996   Yowza -- can see deformation of the hub from the h...   Aug 2 2020, 10:18 AM
ctc911ctc   OK, more heat - less hammer! BTW, the marks t...   Aug 2 2020, 11:16 AM
sixnotfour   https://www.youtube.com/watch?v=DZU_-BLDNAU DZU_-...   Aug 2 2020, 10:43 AM
cuddy_k   At least 5 minutes I would say, but @superhawk996...   Aug 2 2020, 10:56 AM
cuddy_k   double post   Aug 2 2020, 10:56 AM
Superhawk996   :D Like the video and special tool. The princip...   Aug 2 2020, 10:57 AM
sixnotfour   I shouldn't even respond ..but..my motto.. typ...   Aug 2 2020, 11:02 AM
Superhawk996   I shouldn't even respond ..but..my motto.. ty...   Aug 2 2020, 11:11 AM
bobboinski   I have been successful doing this by getting the p...   Aug 2 2020, 11:31 AM
bobboinski   I just looked back at your puller. I use a steerin...   Aug 2 2020, 11:40 AM
ctc911ctc   :shoot2kill: HEAT, MORE HEAT :shoot2kill: W...   Aug 2 2020, 03:38 PM
porschetub   :shoot2kill: HEAT, MORE HEAT :shoot2kill: ...   Aug 2 2020, 05:38 PM
Superhawk996   Well it came off, :Qarl: :cheer:   Aug 3 2020, 06:29 AM
bobboinski   :beer2: No opinion on the plugs, I cleaned mine u...   Aug 2 2020, 05:02 PM
- Lo-Fi Version Time is now: 6th October 2026 - 02:13 PM
