| bkrantz |
Jul 31 2020, 08:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,773 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I have a bunch of questions about restoring the main and engine harnesses.
Any material or process to restore flexibility in the wire insulation? Same for the original outer tubing? For breaks in wires and large holes in the insulation, I think the best solution (short of running a complete new wire) is to solder-splice the break, and cover it with heat-shrink tubing--yes? Any good way to seal small holes and cracks in insultation? When replacing missing or broken spade connectors, crimp only or crimp and solder? |
| bkrantz |
Aug 2 2020, 08:42 PM
A closer look at some of the wires--not very encouraging.
Attached thumbnail(s) |
bkrantz Wiring Harness Restoration Jul 31 2020, 08:41 PM
914e
I have a bunch of questions about restoring the m... Jul 31 2020, 09:32 PM
djway
I have a bunch of questions about restoring the m... Aug 1 2020, 12:22 AM
IronHillRestorations Warming with a hair dryer or heat gun (be very, ve... Aug 1 2020, 04:37 AM
76-914 Use the Marine grade heat shrink if you can find i... Aug 1 2020, 07:02 AM
JeffBowlsby Your intent and motivation is admirable. For the ... Aug 1 2020, 09:35 AM
Superhawk996
Your intent and motivation is admirable. For the... Aug 1 2020, 11:14 AM
Mikey914 Yes you can get new connectors, sleeving materials... Aug 1 2020, 11:05 AM
914Sixer Bite the bullet, buy new reproduction and move on ... Aug 1 2020, 12:41 PM
IronHillRestorations I scanned over "engine harness", and tot... Aug 1 2020, 01:05 PM
mlindner
I scanned over "engine harness", and to... Aug 1 2020, 02:53 PM
mepstein That's why I jumped on this.
The wires are sof... Aug 1 2020, 03:02 PM
windforfun Always crimp first & then solder, not the othe... Aug 1 2020, 03:04 PM
bkrantz Thanks for all the replies. I do appreciate the w... Aug 1 2020, 08:33 PM
IronHillRestorations Get a new FI harness Aug 2 2020, 09:25 PM
bbrock When I restored my main chassis harness, I removed... Aug 2 2020, 10:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th September 2026 - 05:52 AM |
