Product review: Rothsport oil check valve, For the /6 owners |
Mark Henry |
Aug 2 2020, 01:32 PM
Every winter or anytime I didn't drive my 914/6 conversion for more then 2-3 weeks my oil tank would drain down into my sump. Often this would result in oil on the shop floor and the neighbors would call the EPA or fire department when I started my 914 in the spring.
I was on the fence on buying a Rothsport oil check valve then a generous member here offered me one for free (IMG:style_emoticons/default/blink.gif) Story was he bought one, never looked at it and tossed it into his parts bin, only to find out he accidentally bought two. He said I've helped him out a lot over the years and he was just playing it forward. So a big shout out to Mark, member mzapisek, Thank you. (IMG:style_emoticons/default/pray.gif) So this isn't a just got the package in the mail and it "looks" like it works great worthless review. (IMG:style_emoticons/default/dry.gif) I've had this in 914 for almost 4 months and I've been driving at least every 2nd day for the last 3 months. This one is actually the wrong hose size for a 914, but that didn't matter to me as my conversion uses non stock (NPT) adapters. I made new adapters, bought a new late 911 S hose and cut it to fit. But only the check valve nipple size is different, the body and the valve size is still the same. For a stock feed line 914/6 get the smaller nipples, For -AN hose you will have to make adaptors for the check valves metic sized nipples. The valve is a unique cone mounted to a bronze bushed shaft. I can't see any way it could fail, and if it did it would be in the open position. To install you cut 1-1/2" out of the hose and use the supplied ABA clamps torqued to 35 inch pounds. The big tank/engine printing on the valve make proper orientation foolproof. I bought 2 extra clamps from Belmetric for my S hose adapters and BTW these are NOT the common cheap hose clamps. Once installed I filled the tank with 10 liters of oil, checked the level and then the car sat for 3-4 weeks. The oil level never moved. Driving it has made no difference, on startup I have instant oil pressure exactly the same as before. I lie... it made one huge difference, I no longer have to run the engine to check the oil! Of course I quad-triple checked this both ways till I was confident, when running it shows about a 1/4 dipstick fuller than when it's not, but it does this repeatedly. It's so nice to be able to check my oil before starting the teen, especially when I'm in good clothes. So out of 10 I'd give the Rothsport oil check valve a 9.5/10 losing a half point to price. Since I'm a CSOB it would lose a full point, but I'm so happy with the oil check improvement I gave it a half point back. Included with the valve is 2 ABA hose clamps. Yes, I recommend this product. https://www.rothsport.com/Products/Engine/O...heck-Valves.htm Attached image(s) |
Mark Henry |
Aug 3 2020, 03:26 PM
Question I just got asked below in PM.
Be aware my return hose is NOT the correct 914/6 size. It is all custom, or a hack if you like and uses the later and much bigger 911 S-hose. QUOTE Mark, I am in the process of getting everything purchased and setup for my 6 conversion. Can you tell me what your configuration was from the tank to the oil cooler? I know you just posted about the check valve. What size AN fittings are you running? Where did you place the drain valve? Thanks Nick Not much of mine you can buy off the shelf, other than the parts I bought to custom fab new parts from. Not worth it unless you have a welder, lathe, etc. and a bunch of free time. -I have a new DWD tank sort of like Ben's (mb911) tank, that I bought off of a member. -2 short bits of 911 OE cohline hose spiced together, this is my tank down hose. -J-hook I made from 1/8th" steel. -The T fitting I re-fabricated an NPT T-fitting with a OE cohline male one end and OE size S-hose male nipple the other end all TIG welded, lathe re-drilled, etc. -new 911 S-hose, cut for new app with the Rothsport valve spliced in. -The cooler I TIG welded on a 1" NPT female aluminum 90-elbow, originally for farm/HE gas pumping hose, the type of refueling tanks you see in the back of pick up trucks. -it has a male 1"NPT nipple fitting that I cut, welded to build up the new S-hose barb and then turned on a lathe. I only have about $100 into my return hose and cooler (not including the tank or check valve), but that's not counting time, tools and some of the hose parts I had. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:47 AM |
