| partwerks |
Aug 4 2020, 09:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
On the turn signal switch, if one side is not cancelling out. Is something inside that's causing it, fixable?
| dangrouche |
Aug 5 2020, 08:11 AM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Check the steering wheel canceling ring as well. It’s on the back of the hub. I’ve had a turn signal switch that appeared intact but did not cancel. It can be tested when the steering wheel is removed. Turn signal left or right and at the three o’clock position force the tab with a small flat blade screwdriver Up Or down
partwerks Turn signal switch Aug 4 2020, 09:23 PM
nditiz1 If you pull off the wheel you can determine what t... Aug 4 2020, 10:03 PM
Steve It seems the aftermarket horn ring and tab are too... Aug 5 2020, 09:23 AM
PanelBilly Take some photos and show us how you fix it Aug 5 2020, 09:47 AM
cary
Me t... Aug 6 2020, 08:33 AM
partwerks I was told:
If it seems sluggish or sticks moving... Aug 6 2020, 08:03 PM
FlacaProductions Agreed with @partwerks on the screw adjustment. ... Aug 7 2020, 10:41 AM
nditiz1 Inspired by @[url=http://www.914world.com/bbs2/in... Aug 7 2020, 12:25 PM
cuddy_k Ha! Great information there!
You may want... Aug 7 2020, 04:11 PM
partwerks
All tabs look ok. Loosened the 4 screws a bit, ... Aug 8 2020, 08:54 PM
FlacaProductions i'd loosen the 4 screws a bit more and wiggle ... Aug 8 2020, 09:26 PM
partwerks
i'd loosen the 4 screws a bit more and wiggle... Aug 8 2020, 09:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:10 PM |
