New problem, Slits? Maybe you can help with this one |
skline |
Dec 18 2004, 12:24 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Got the brakes all done with all new lines, no leaks. Went to put in the bolts for the ball joints and they dont fit. Aaron was here and thinks I either have the wrong ball joints or the wrong bolts. The struts must be early struts and I got the later ball joints. I can run a bolt all the way through and put a nut on it but the tapered ones will not fit. The strut itself is threaded on one side with a larger hole on the other side. Can someone tell me what I need to put in there, That is all that is left to do.
SLITS |
Dec 18 2004, 12:31 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Since Dr. 914 or Greg isn't here, it is my belief you have the early struts that have the pinch bolt and not the double taper bolt. The double taper style is not threaded on the one side, it has a thru-hole (Britney) with a nut and lock washer.
Sorry Scott, I am serious. Did your front rotors have the hub centering ring? If you need a set of late struts, you know where they are........... |
Lo-Fi Version | Time is now: 7th June 2024 - 09:03 PM |
