New problem, Slits? Maybe you can help with this one |
skline |
Dec 18 2004, 12:24 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Got the brakes all done with all new lines, no leaks. Went to put in the bolts for the ball joints and they dont fit. Aaron was here and thinks I either have the wrong ball joints or the wrong bolts. The struts must be early struts and I got the later ball joints. I can run a bolt all the way through and put a nut on it but the tapered ones will not fit. The strut itself is threaded on one side with a larger hole on the other side. Can someone tell me what I need to put in there, That is all that is left to do.
SLITS |
Dec 18 2004, 12:43 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I have a 914/6 front strut assembly and would have to look at it tomorrow as I don't remember how the ball joint attaches. That said and it is threaded, it's got to be a pinch bolt setup and part of the bolt would prolly fit in the groove in the ball joint shaft to keep it located. I do not know the shape of the bolt on this style (meaning if it has a partially unthreaded shank and is larger diameter in that portion).
You need help from the "Dark Side" guys. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:43 AM |
