Axle bolts and Pins, I done messed up |
tvdinnerbythepool |
Aug 7 2020, 07:56 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Axle fell of the transmission yesterday. Bent a bolt and sheared a bolt. The other two appear to be fine and just loosened themselves out.
My assumption is I didn't torque them down correctly. Question is..... Bolt size? I have M8 special bit And... There are 6 holes....4 bolts and 2 alignment pins correct? I appear to have lost those 2 pins when the axle came off. Source for the 2 pins? Thanks all! -R |
bdstone914 |
Aug 7 2020, 09:17 AM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
All good advise. Another tip is put a drop of paint on the base of the head on each bolt and on the flange. Inspect occasionally. If the punt marks do not align they are backing off.
Superhawk996 |
Aug 7 2020, 09:25 AM
914 Guru Group: Members Posts: 5,869 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
All good advise. Another tip is put a drop of paint on the base of the head on each bolt and on the flange. Inspect occasionally. If the punt marks do not align they are backing off. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 02:25 AM |
