New problem, Slits? Maybe you can help with this one |
skline |
Dec 18 2004, 12:24 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Got the brakes all done with all new lines, no leaks. Went to put in the bolts for the ball joints and they dont fit. Aaron was here and thinks I either have the wrong ball joints or the wrong bolts. The struts must be early struts and I got the later ball joints. I can run a bolt all the way through and put a nut on it but the tapered ones will not fit. The strut itself is threaded on one side with a larger hole on the other side. Can someone tell me what I need to put in there, That is all that is left to do.
SLITS |
Dec 18 2004, 01:17 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Look carefully and see if the hole thru the strut is tapered and see if you can see the groove in the ball joint shaft.
I can't answer the safety question, but the bolt should clamp the ball joint shaft......I just don't know if it is tapered to provide an interference fit. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:42 AM |
