Axle bolts and Pins, I done messed up |
tvdinnerbythepool |
Aug 7 2020, 07:56 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Axle fell of the transmission yesterday. Bent a bolt and sheared a bolt. The other two appear to be fine and just loosened themselves out.
My assumption is I didn't torque them down correctly. Question is..... Bolt size? I have M8 special bit And... There are 6 holes....4 bolts and 2 alignment pins correct? I appear to have lost those 2 pins when the axle came off. Source for the 2 pins? Thanks all! -R |
IronHillRestorations |
Aug 8 2020, 05:10 AM
I. I. R. C. Group: Members Posts: 6,725 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I don’t know if it makes a difference but I like to put the bolts in without the washers, pull the CV/gasket/flange assembly together, take off the bolts one at a time and put a new Schnorr washer on each bolt and torque to spec (31 ft lbs IIRC)
Lo-Fi Version | Time is now: 4th June 2024 - 07:05 AM |
