| partwerks |
Aug 4 2020, 09:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
On the turn signal switch, if one side is not cancelling out. Is something inside that's causing it, fixable?
| partwerks |
Aug 8 2020, 08:54 PM
All tabs look ok. Loosened the 4 screws a bit, but still drags a bit. I sprayed some contact cleaner in there. Seemed to help, so might use the air hose to blow anything else out? Seems like it might just be gummed up? |
partwerks Turn signal switch Aug 4 2020, 09:23 PM
nditiz1 If you pull off the wheel you can determine what t... Aug 4 2020, 10:03 PM
dangrouche Check the steering wheel canceling ring as well. I... Aug 5 2020, 08:11 AM
Steve It seems the aftermarket horn ring and tab are too... Aug 5 2020, 09:23 AM
PanelBilly Take some photos and show us how you fix it Aug 5 2020, 09:47 AM
cary
Me t... Aug 6 2020, 08:33 AM
partwerks I was told:
If it seems sluggish or sticks moving... Aug 6 2020, 08:03 PM
FlacaProductions Agreed with @partwerks on the screw adjustment. ... Aug 7 2020, 10:41 AM
nditiz1 Inspired by @[url=http://www.914world.com/bbs2/in... Aug 7 2020, 12:25 PM
cuddy_k Ha! Great information there!
You may want... Aug 7 2020, 04:11 PM
FlacaProductions i'd loosen the 4 screws a bit more and wiggle ... Aug 8 2020, 09:26 PM
partwerks
i'd loosen the 4 screws a bit more and wiggle... Aug 8 2020, 09:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:12 PM |
