| partwerks |
Aug 4 2020, 09:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
On the turn signal switch, if one side is not cancelling out. Is something inside that's causing it, fixable?
| FlacaProductions |
Aug 8 2020, 09:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
i'd loosen the 4 screws a bit more and wiggle the switch back toward you 1/8-1/4 inch or so if you can. see if that makes the turn signal stop binding. if so...slide it back in and just barely tighten the screws down. blowing out the crud and a little lube can't hurt.
| partwerks |
Aug 8 2020, 09:54 PM
i'd loosen the 4 screws a bit more and wiggle the switch back toward you 1/8-1/4 inch or so if you can. see if that makes the turn signal stop binding. if so...slide it back in and just barely tighten the screws down. blowing out the crud and a little lube can't hurt. I wonder once I get it cleaned out, if putting some graphite in there would be the right, or the wrong thing to do?? I would assume the turn signal can be separated from the wipers, and maybe cleaned up better? |
partwerks Turn signal switch Aug 4 2020, 09:23 PM
nditiz1 If you pull off the wheel you can determine what t... Aug 4 2020, 10:03 PM
dangrouche Check the steering wheel canceling ring as well. I... Aug 5 2020, 08:11 AM
Steve It seems the aftermarket horn ring and tab are too... Aug 5 2020, 09:23 AM
PanelBilly Take some photos and show us how you fix it Aug 5 2020, 09:47 AM
cary
Me t... Aug 6 2020, 08:33 AM
partwerks I was told:
If it seems sluggish or sticks moving... Aug 6 2020, 08:03 PM
FlacaProductions Agreed with @partwerks on the screw adjustment. ... Aug 7 2020, 10:41 AM
nditiz1 Inspired by @[url=http://www.914world.com/bbs2/in... Aug 7 2020, 12:25 PM
cuddy_k Ha! Great information there!
You may want... Aug 7 2020, 04:11 PM
partwerks
All tabs look ok. Loosened the 4 screws a bit, ... Aug 8 2020, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:11 PM |
