New problem, Slits? Maybe you can help with this one |
skline |
Dec 18 2004, 12:24 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Got the brakes all done with all new lines, no leaks. Went to put in the bolts for the ball joints and they dont fit. Aaron was here and thinks I either have the wrong ball joints or the wrong bolts. The struts must be early struts and I got the later ball joints. I can run a bolt all the way through and put a nut on it but the tapered ones will not fit. The strut itself is threaded on one side with a larger hole on the other side. Can someone tell me what I need to put in there, That is all that is left to do.
skline |
Dec 18 2004, 09:54 AM
Yeah, got to bed around 12:30. Thanks to Aaron for coming out and lending a hand and Slits for the board and phone assistance. I just got up and came out here to the garage. I am going to switch the front ball joint bolts around and double check everything to make sure it's done and then take this thing for a cruise around the block. Its still a little cool out here in the garage so motivation is low right now. But I will drive it today for sure. I need someone to come take the video for me. It will most likely be around noon or so. Any volunteers?
Lo-Fi Version | Time is now: 7th June 2024 - 07:18 PM |
