> Cigarette Lighter, Easiest way to get to power and ground in back
Baumgardner
post Aug 13 2020, 05:43 PM
I am wiring the radio in my '72 914. (There is no old wiring). It would seem pretty simple - just run the ground and power to the back of the cigarette lighter running off Fuse 8. However, I cannot contort my body to get to it. From researching some other threads, some said you have to go inside the luggage compartment, remove the blower, and then access it that way. Ugh. Another said "there is a push on ring that holds the lighter housing against the dash. Get a hold of the lighter under the dash and wiggle to loosen up the grip from the ring to the lighter body. Then keep pushing and shortly it will be obvious and be out." Anyone have any thoughts on this? Not sure which of these should be pursued or if there is another way to access. Thanks.
post Aug 13 2020, 07:21 PM
(IMG:style_emoticons/default/agree.gif) Easy peasy this way. (IMG:style_emoticons/default/beerchug.gif)
EDIT: You'll need to disconnect the cable from the rear of the speedo and the trip reset from the lower lip of the dash if it has one.
- Lo-Fi Version Time is now: 1st August 2025 - 05:38 AM
