| ballsyfacts914 |
Aug 14 2020, 12:13 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All,
Hope everyone is staying safe! I recently had an issue where my shifting rod came apart while driving, luckily it was at a stop light and I was able to get out of traffic easily and safely. However, this required a tow and a trip to the mechanic....obviously. Before this, my shifting had always been a little troublesome so I had gotten into the habit of being very mindful of my shifting, not shifting too fast or abruptly. After getting the car back from the mechanic, the shifting was the best it had ever been, however, I noticed the function of the stop plate was nowhere near what it had previously been (non-existent as if it wasn't a part of the shift assembly). This wasn't a big concern to me though as the shifting was near perfect, the only real issue was I would nick reverse from time to time going from first to second. Before this, I had been looking for a more experienced 914 mechanic and when I did take the car into the new mechanic he mentioned the shifting was not like a 914. At the time I didn't want any adjustments made but now I am starting to think I should. As mentioned, the stop plate is there but there is no obvious feel of it being there. In fact, even when I really pull the shifter to the left there is barely any give as one would expect. Other than nicking reverse on occasion the car shifts beautifully. Any suggestions on what the issue may be? I haven't taken anything apart yet but based on my previous experience and how it current appears, I see no issues. Thanks |
| porschetub |
Aug 14 2020, 02:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,029 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Adjust it correctly and if you still have an issue remove the bolt directly under the shifter and remove it,when the shifter is out you can inspect the stop plate.
Check to see if the plate isn't hollowed out instead of being straight,the shifter lever itself can be chewed out where it contacts the plate ,this can compound the issue. If you are paying some one to do this and there is a lot of wear you may be better off finding a good used assembly,new stop plates aren't cheap and the labour to fit will be up there as its a pig of a job. Good luck. |
ballsyfacts914 1975 Possible Stop Plate Issue Aug 14 2020, 12:13 PM
lierofox On the later side shift 914's the shifter alig... Aug 14 2020, 01:20 PM
ballsyfacts914
On the later side shift 914's the shifter ali... Aug 14 2020, 05:16 PM
ballsyfacts914
Adjust it correctly and if you still have an issu... Aug 14 2020, 05:10 PM
rhodyguy Are you referring to the 1/R lockout plate inside ... Aug 14 2020, 02:42 PM
ballsyfacts914
Are you referring to the 1/R lockout plate inside... Aug 14 2020, 05:06 PM
914 Ranch Ture the plate over. I have been through this befo... Aug 15 2020, 05:08 AM
ballsyfacts914
Ture the plate over. I have been through this bef... Aug 15 2020, 09:50 AM
rhodyguy Does the contact edge look like 'A' :firs... Aug 15 2020, 10:04 AM
ballsyfacts914
Does the contact edge look like 'A' :fir... Aug 15 2020, 11:48 AM
Bleyseng Fix it as nicking R going from 1st isn't bad f... Aug 15 2020, 12:25 PM
ballsyfacts914
Fix it as nicking R going from 1st isn't bad ... Aug 15 2020, 03:26 PM
rhodyguy Cheaper than syncros and while your in there. Aug 15 2020, 12:37 PM
ballsyfacts914 Hi All,
Thanks again for all the replies. Wanted ... Aug 17 2020, 04:00 PM
rhodyguy If you're happy with the way it shifts, mark t... Aug 17 2020, 04:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:03 AM |
