| Morph914 |
Aug 15 2020, 12:46 PM
Member ![]() ![]() Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States
Today I was installing my new PMB rotors and calipers, but it seems I took 1 step forward and 2 back. I purchased the late 5 lug conversion kit from PMB and I believe I received the wrong front rotors. (IMG:style_emoticons/default/headbang.gif)
After installing the rotors, I went to install the calipers and they did not line up. After doing some investigative work I discovered that my old rotors are a bit different, the hat is taller and the inside oil seal surface is recessed about a 1/4” where the new one seems to be flush with the rotor surface. I’ll have to wait until Monday to sort this out with Eric. ![]() |
| bdstone914 |
Aug 15 2020, 01:44 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,295 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What year us your car? The rotors change in 72 at vin 19033. Why is there an inner bearing race on the rotor by the spindle nut.
Morph914 Front brake problem Aug 15 2020, 12:46 PM
Morph914
What year us your car? The rotors change in 72 at... Aug 15 2020, 04:59 PM
dr914@autoatlanta.com looks like you have an early rotor mounted that wo... Aug 17 2020, 09:33 AM
Literati914 There are three different hub thicknesses... did P... Aug 15 2020, 02:46 PM
Morph914
There are three different hub thicknesses... did ... Aug 15 2020, 05:01 PM
davep
I am a... Aug 16 2020, 02:16 PM
Cairo94507 Great catch Bruce. :beer2: Aug 15 2020, 03:26 PM
Literati914
I am ... Aug 16 2020, 06:41 PM
davep Okay, I see the problem. You are referring to 911/... Aug 17 2020, 08:34 AM
Literati914
Okay, I see the problem. You are referring to 911... Aug 17 2020, 10:37 PM
davep Absolutely 3 unused holes; the one on the left is ... Aug 18 2020, 09:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 01:52 PM |
