| Tdskip |
Aug 17 2020, 09:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,767 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning. On big Type4 engines that are going to be used on the street, it appears that keeping a stock flywheel is a plus for drivability but I’m also wondering if the bigger engines have enough torque that they can handle it lighter flywheel for a bit more zing of an experience.
The one that was on this 2.7 L motor I’m sorting out was shaved down to 12.3 pounds which seems a bit to light for street use. EDIT - did some researching it appears that too light of a flywheel will make the car a pain on the highway, so maybe just stick with stock weight? |
| Montreal914 |
Aug 19 2020, 09:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,091 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Coming back to the OP's original question, i.e. the use of a lightened flywheel on a stroker engine...
Yes, a lightened flywheel will give you quicker rev and require more RPM at the start for obvious reasons. But, the stroker cranks also have added rotational mass with the counterweight and the engine has a lot more torque due to its longer stroke. So the question could be, does the cranks added mass could compensate for a flywheel mass reduction? (IMG:style_emoticons/default/idea.gif) What have people experienced with stroker engines? (IMG:style_emoticons/default/smile.gif) |
Tdskip Pros/cons of lightened flywheels on stroker engines Aug 17 2020, 09:49 AM
ClayPerrine We have run a lightened flywheel for years. It is... Aug 17 2020, 10:16 AM
Steve
Good morning. On big Type4 engines that are going... Aug 17 2020, 10:16 AM
SKL1 I've had a lightened flywheel on my '71 2.... Aug 17 2020, 10:31 AM
thelogo
Good morning. On big Type4 engines that are going... Aug 17 2020, 11:54 AM
Mueller
[quote name='Tdskip' post='2843457' date='Aug 17 ... Aug 17 2020, 12:59 PM
thelogo
[quote name='Tdskip' post='2843457' date='Aug 17... Aug 17 2020, 02:26 PM
914werke
We have run a lightened flywheel for years. It i... Aug 17 2020, 12:22 PM
mbseto Quicker throttle response but higher RPMs needed b... Aug 17 2020, 01:10 PM
Jack Standz
Good morning. On big Type4 engines that are going... Aug 17 2020, 01:21 PM
Tdskip Good morning gentlemen. I ended up sourcing a fact... Aug 19 2020, 07:21 AM
Mark Henry Funny thing is have you ever felt how heavy a 930 ... Aug 19 2020, 09:27 AM
Tdskip Interest and consideration on what the net loss in... Aug 19 2020, 11:54 AM
gandalf_025 My lightened flywheel experience isn't from a ... Aug 19 2020, 12:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 12:37 PM |
