| djway |
Apr 11 2020, 11:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
OK L Jet people, if you could choose between an L Jet system that consisted of the 6 pin AFM and a 74 Brain or a 7 pin AFM and a 76 Brain which would you choose and why?
Discuss. (IMG:style_emoticons/default/smile.gif) |
| djway |
Aug 22 2020, 11:46 PM
I believe I had/have multiple issues.
I replaced the yellow wire fitting onto the relay as it seemed weak, fragile. After that I was concerned that the ignition switch was acting up so I connected a remote start switch to the starter. The pump would activate but nothing from the never used before starter. The ignition switch also activated the pump but nothing from the starter. So, junk starter, possible intermittent contact at the relay from a bad connection, jury still out on the ignition switch. Got a starter from a friend and got it back in with the help of a friend with tiny hands, appropriately masked of course. Will attempt to start again tomorrow but first I will find a young hippie chick to burn some sage, dance and sing. (IMG:style_emoticons/default/wacko.gif) |
| rbzymek |
Aug 23 2020, 08:11 AM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest
I believe I had/have multiple issues. I replaced the yellow wire fitting onto the relay as it seemed weak, fragile. After that I was concerned that the ignition switch was acting up so I connected a remote start switch to the starter. The pump would activate but nothing from the never used before starter. The ignition switch also activated the pump but nothing from the starter. So, junk starter, possible intermittent contact at the relay from a bad connection, jury still out on the ignition switch. Got a starter from a friend and got it back in with the help of a friend with tiny hands, appropriately masked of course. Will attempt to start again tomorrow but first I will find a young hippie chick to burn some sage, dance and sing. (IMG:style_emoticons/default/wacko.gif) Here is another test you can do. Remove the air cleaner. Place the key in RUN and push on the air vane. This should cause the pump to run. On a normal start the fuel pump is powered during crank. When the engine fires the air flow moves the vane, closes a switch and keeps the pump running. You may already know this but I could not tell from your trials. |
djway Question for the L Jet Gang Apr 11 2020, 11:47 PM
ClayPerrine
OK L Jet people, if you could choose between an L... Apr 12 2020, 07:32 AM
djway
OK L Jet people, if you could choose between an ... Apr 12 2020, 03:47 PM
r_towle Well, one has 6 pins and one has 7 pins
More is be... Apr 12 2020, 09:58 PM
djway The seventh pin is a direct line to the temp senso... Apr 12 2020, 10:36 PM
ejm
OK L Jet people, if you could choose between an L... Apr 13 2020, 05:13 AM
ClayPerrine
OK L Jet people, if you could choose between an ... Apr 13 2020, 06:36 AM
djway Tracking down issue on why the motor won't sta... Aug 22 2020, 12:22 AM
porschetub
Tracking down issue on why the motor won't st... Aug 22 2020, 11:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 09:35 AM |
