| shane |
Aug 25 2020, 05:27 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
My first air cooler (type 4) so excuse my possible ignorance, but does a normal good running type 4 sound a little clangy and tappy until you rev her up a bit? Have the timing set and good plugs Also adjusted the valves. Just wanted to know if things are normal or maybe I have big problems. Thanks
| SirAndy |
Aug 25 2020, 08:41 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,369 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My first air cooler (type 4) so excuse my possible ignorance, but does a normal good running type 4 sound a little clangy and tappy until you rev her up a bit? Have the timing set and good plugs Also adjusted the valves. Just wanted to know if things are normal or maybe I have big problems. Thanks Does it have hydraulic lifters? They tend to make a lot of noise when dry. (IMG:style_emoticons/default/idea.gif) |
| shane |
Aug 25 2020, 09:48 PM
My first air cooler (type 4) so excuse my possible ignorance, but does a normal good running type 4 sound a little clangy and tappy until you rev her up a bit? Have the timing set and good plugs Also adjusted the valves. Just wanted to know if things are normal or maybe I have big problems. Thanks Does it have hydraulic lifters? They tend to make a lot of noise when dry. (IMG:style_emoticons/default/idea.gif) Funny you would say that it actually does, it’s the stock 1.8 block and 1.8 heads But it has hydraulics. Got no info about the engine from the PO cause he owned it for a short time and said he needed room in his garage for his sportster he just got. All he told me Was it was Southern Cali car and I just figured that’s what everyone says. But doing the restoration on it I found a postcard that slipped down below the fresh air blower That was address to a lady in Santa Barbra so Huh. |
| SirAndy |
Aug 25 2020, 11:45 PM
My first air cooler (type 4) so excuse my possible ignorance, but does a normal good running type 4 sound a little clangy and tappy until you rev her up a bit? Have the timing set and good plugs Also adjusted the valves. Just wanted to know if things are normal or maybe I have big problems. Thanks Does it have hydraulic lifters? They tend to make a lot of noise when dry.(IMG:style_emoticons/default/idea.gif) That's your noise right there. Hydraulic lifters need oil inside to work properly and if they sit for too long they will drain and need some time to build up pressure again. My 3.6L /6 does the same thing if i haven't driven it for a while. I usually let it idle for a few minutes and slowly rev it up until the noise goes away. Just don't try to force it by reving it too high too early. (IMG:style_emoticons/default/bye1.gif) |
shane Finally got her on the road! Aug 25 2020, 05:27 PM
fiacra Yeah, that sounds like a Porsche/VW air cooled eng... Aug 25 2020, 06:26 PM
Cairo94507 Ditto. Please post up a video of the engine sound... Aug 25 2020, 06:32 PM
Jamie
Ditto. Please post up a video of the engine soun... Aug 25 2020, 06:40 PM
fiacra
Ditto. Please post up a video of the engine sou... Aug 25 2020, 06:44 PM
shane Great I’ll get on it, not at all trying to be in... Aug 25 2020, 07:02 PM
bbrock IMO the Type 4 sounds like a box of buffalo farts.... Aug 25 2020, 08:21 PM
shane
[quote name='SirAndy' post='2845951' date='Aug 2... Aug 26 2020, 07:53 AM
Superhawk996
Not quite a Ferrari growl.
:shades2: Aug 26 2020, 11:12 AM
Root_Werks
My first air cooler (type 4) so excuse my possibl... Aug 26 2020, 11:38 AM
PanelBilly Bring it down to Piketon's Saturday night and ... Aug 25 2020, 09:06 PM
shane
Bring it down to Piketon's Saturday night and... Aug 25 2020, 09:57 PM
shane Found it El Piketon restaurant in Kent We’ll mak... Aug 25 2020, 10:55 PM
Tdskip Belated welcome, and as you found out this is a gr... Aug 26 2020, 08:30 AM
Spoke I have a 2056 and it sounds like there's a buc... Aug 26 2020, 09:51 AM
rjames Make sure your setting the gap for the hydraulic l... Aug 26 2020, 11:05 AM
porschetub
Make sure your setting the gap for the hydraulic ... Aug 26 2020, 06:56 PM
shane Thanks for all the thoughts and advice and threads... Aug 26 2020, 07:48 PM
shane RE: Finally got her on the road! Aug 27 2020, 02:59 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:02 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:06 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:13 PM
mrholland2
There's one problem. The single carb.
i... Aug 27 2020, 04:24 PM
mrholland2
... Aug 27 2020, 04:26 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:15 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:18 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:20 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:22 PM
shane RE: Finally got her on the road! Aug 27 2020, 03:25 PM
shane The PO had the carb on there but I have all the FI... Aug 27 2020, 03:33 PM
Root_Werks That 914 has really come together, nice job! ... Aug 27 2020, 03:39 PM
Tdskip She looks great, nice job on the paint. Aug 27 2020, 03:39 PM
ndfrigi congratulations! that is beautiful and very cl... Aug 27 2020, 04:30 PM
shane Thanks everyone :beer2: I usually don’t take pi... Aug 27 2020, 04:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:39 PM |
