| michelko |
Aug 26 2020, 10:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi ,
i found an issue that i think it´s not ok. The upper mount of the rear shocks has two rubber bushings. I believe the buschings should be pressed together from the nut on top of the schock. On my car this is not so. The upper rubber piece is loose an can be moved and turned. Here is a pic and a video that shows what i mean. Any thoughts how this must be? https://youtu.be/4fTn4ur3C0w Regards Michael |
rhodyguy You're missing the metal cap that goes on top ... Aug 26 2020, 10:40 AM
914forme PM me I have some just cover shipping and they are... Aug 26 2020, 10:51 AM
mepstein https://nemigaparts.com/cat_spares/pet/pors...14/5... Aug 26 2020, 10:56 AM
michelko Hi and thanks for the offers but there is a misund... Aug 26 2020, 02:13 PM
JamesM
Hi and thanks for the offers but there is a misun... Aug 26 2020, 02:40 PM
914forme James that is the nut that supports the rubber I a... Aug 26 2020, 05:11 PM
914e Did you replace bushings 11 and 12 in the drawing?... Aug 26 2020, 05:51 PM
michelko Hi,
those rubber parts are old as the car, so now ... Aug 27 2020, 12:26 AM
michelko Hm i found this picture in the repair manual. Here... Aug 27 2020, 12:33 AM
kroelofsen
Hm i found this picture in the repair manual. Her... Aug 27 2020, 05:48 AM
[quote name='michelko' post='2846283' date='Aug 2... Aug 27 2020, 05:54 AM
davep 11 perch sits halfway down the shock tube
10 metal... Aug 27 2020, 07:14 AM
914forme Nope that 4 MM does nothing for the spacing of the... Aug 27 2020, 07:27 AM
michelko
Nope that 4 MM does nothing for the spacing of th... Aug 27 2020, 07:45 AM
JamesM
Nope that 4 MM does nothing for the spacing of th... Aug 27 2020, 09:37 AM
74ravenna
Nope that 4 MM does nothing for the spacing of th... Oct 15 2020, 10:19 AM
Mikey914 My money is the #10 is sitting higher due to a dif... Aug 27 2020, 08:18 AM
michelko
My money is the #10 is sitting higher due to a di... Aug 27 2020, 11:49 AM
ndfrigi I think you need to check the ff:
# 3 and 4 if ha... Aug 27 2020, 08:46 AM
Retroracer A cross-section of an assembled strut would help v... Aug 27 2020, 09:57 AM
914e Ian has the great video that might help you.
http... Aug 27 2020, 02:23 PM
cary Just did new Bilsteins on Matt Carey's 26k bar... Oct 15 2020, 09:40 PM
74ravenna Thanks Cary. Mine were Fragments also. Good to kno... Oct 16 2020, 03:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd September 2026 - 08:42 AM |
