> Rubber on rear shock tower is that right?
michelko
post Aug 26 2020, 10:02 AM
Hi ,
i found an issue that i think it´s not ok.
The upper mount of the rear shocks has two rubber bushings.
I believe the buschings should be pressed together from the nut on top of the schock.
On my car this is not so. The upper rubber piece is loose an can be moved and turned.
Here is a pic and a video that shows what i mean.
Any thoughts how this must be?
https://youtu.be/4fTn4ur3C0w
Regards Michael
michelko
post Aug 26 2020, 02:13 PM
Hi and thanks for the offers but there is a misunderstanding.
I have all the hardware here. The pic was to show that the rubber is maybe not high enough.
If i put the washer and the nut in place there is a gap remaining between rubber and washer.
You can see this in the short video.
I like to if thhis gap is normal or if the lower rubber is bad.
Regards Michael
JamesM
post Aug 26 2020, 02:40 PM
QUOTE(michelko @ Aug 26 2020, 12:13 PM) *
Regards Michael
If there is slop in the connection when tightened down, its not normal. either missing hardware or bad rubber (upper or lower) or possibly bad tolerances on the shock, but that seems unlikely)
Two things come to mind because i have seen them missing on a few cars.
1. the stock bump stops (part 6) have a metal washer integrated in them, they install under the upper perch and space everything above them up about ~3mm. Without that washer you wind up with the shaft sticking above the rubber like you are seeing.
2. Washer/spacer (part 9) i see missing a lot would have the same effect.
As you mentioned you have all the parts, im leaning towards #1 as afaik the proper bump stops are not available and all the originals have more or less dissolved at this point. All the replacements i have seen are all rubber and slide on the shaft vs mounting under the upper spring perch.
michelko   Rubber on rear shock tower is that right?   Aug 26 2020, 10:02 AM
rhodyguy   You're missing the metal cap that goes on top ...   Aug 26 2020, 10:40 AM
914forme   PM me I have some just cover shipping and they are...   Aug 26 2020, 10:51 AM
mepstein   https://nemigaparts.com/cat_spares/pet/pors...14/5...   Aug 26 2020, 10:56 AM
michelko   Hi and thanks for the offers but there is a misund...   Aug 26 2020, 02:13 PM
JamesM   Hi and thanks for the offers but there is a misun...   Aug 26 2020, 02:40 PM
914forme   James that is the nut that supports the rubber I a...   Aug 26 2020, 05:11 PM
914e   Did you replace bushings 11 and 12 in the drawing?...   Aug 26 2020, 05:51 PM
michelko   Hi, those rubber parts are old as the car, so now ...   Aug 27 2020, 12:26 AM
michelko   Hm i found this picture in the repair manual. Here...   Aug 27 2020, 12:33 AM
kroelofsen   Hm i found this picture in the repair manual. Her...   Aug 27 2020, 05:48 AM
mepstein   [quote name='michelko' post='2846283' date='Aug 2...   Aug 27 2020, 05:54 AM
davep   11 perch sits halfway down the shock tube 10 metal...   Aug 27 2020, 07:14 AM
914forme   Nope that 4 MM does nothing for the spacing of the...   Aug 27 2020, 07:27 AM
michelko   Nope that 4 MM does nothing for the spacing of th...   Aug 27 2020, 07:45 AM
JamesM   Nope that 4 MM does nothing for the spacing of th...   Aug 27 2020, 09:37 AM
74ravenna   Nope that 4 MM does nothing for the spacing of th...   Oct 15 2020, 10:19 AM
Mikey914   My money is the #10 is sitting higher due to a dif...   Aug 27 2020, 08:18 AM
michelko   My money is the #10 is sitting higher due to a di...   Aug 27 2020, 11:49 AM
ndfrigi   I think you need to check the ff: # 3 and 4 if ha...   Aug 27 2020, 08:46 AM
Retroracer   A cross-section of an assembled strut would help v...   Aug 27 2020, 09:57 AM
914e   Ian has the great video that might help you. http...   Aug 27 2020, 02:23 PM
cary   Just did new Bilsteins on Matt Carey's 26k bar...   Oct 15 2020, 09:40 PM
74ravenna   Thanks Cary. Mine were Fragments also. Good to kno...   Oct 16 2020, 03:25 AM
- Lo-Fi Version Time is now: 23rd September 2026 - 08:41 AM
