Battery of choice |
Battery of choice |
mlindner |
Aug 8 2020, 08:10 AM
Senior Member Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
For mostly track car. what batteries are you using. And images of rear trunk installation.
campbellcj |
Aug 23 2020, 07:34 AM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've got the Odyssey PC680 which is the tiny AGM similar to above, which is mounted on its side in the factory battery tray. It holds charge well - I disconnect for storage - and cranks my fairly high compression 2.7/six just fine.
Krieger |
Aug 26 2020, 11:08 PM
Advanced Member Group: Members Posts: 4,727 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I've got the Odyssey PC680 which is the tiny AGM similar to above, which is mounted on its side in the factory battery tray. It holds charge well - I disconnect for storage - and cranks my fairly high compression 2.7/six just fine. (IMG:style_emoticons/default/agree.gif) I have this in both my 914s. Cranks the high compression 3.0 six with no problem. The one in my four cylinder is seven years old and is finally starting to show signs of slow cranking on start up after the car sits for a few weeks. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:25 PM |
