| goobstine |
Aug 21 2020, 10:23 PM
Newbie ![]() Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
will a type 4 vanagon crank slip into a type 4 914 case?
will a 2.0 crank fit into a 1.7 case with out machining ? will a 200 mm flywheel and pressure plate that is made to fit type 4 crank work okay with 1.7 thru 2.0 ? will 215mm flywheel from bus be okay with 914 transmission ? bus crank has pilot bearing in shaft 914 has in flywheel how do i go about using bus crank in 914 engine thank you ! |
| jd74914 |
Aug 27 2020, 12:02 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,885 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Try contacting the Jesco Reient (John). He built cutting fixtures to align-bore cases and has done quite a lot.
http://www.914world.com/bbs2/index.php?sho...=236879&hl= |
goobstine type 4 line bore Aug 21 2020, 10:23 PM
porschetub
will a type 4 vanagon crank slip into a type 4 91... Aug 21 2020, 11:47 PM
goobstine
will a type 4 vanagon crank slip into a type 4 9... Aug 22 2020, 12:32 AM
goobstine
will a type 4 vanagon crank slip into a type 4 9... Aug 22 2020, 12:36 AM
goobstine
will a type 4 vanagon crank slip into a type 4 9... Aug 26 2020, 11:11 PM
Mark Henry Is this going into a bus, bug or a 914?
-914 trans... Aug 22 2020, 11:08 AM
goobstine
-914 tran... Aug 26 2020, 10:59 PM
goobstine
-914 tra... Aug 26 2020, 11:23 PM
914e You might see if the people at Chirco can recommen... Aug 22 2020, 03:03 PM
goobstine
You might see if the people at Chirco can recomme... Aug 26 2020, 11:21 PM
iankarr You could always send it to European motor works i... Aug 23 2020, 09:45 AM
michael7810 You might give Dan a call at CEVW in Phoenix. Heā... Aug 27 2020, 07:51 AM
ThinAir
You might give Dan a call at CEVW in Phoenix. Heā... Sep 15 2020, 11:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st August 2026 - 09:16 PM |
