> 914/6 alternate rear calipers
Racer
post Aug 31 2020, 10:12 AM
The rear factory calipers on my 914/6 are giving me some annoyance. In this case, the passenger side rear caliper has developed a slight weap. Its been an issue for the past two years. I've addressed the hard line, soft line and had the caliper re-built, but still, there is a slight leak.
Since 914/6 rear calipers are somewhat difficult to find in working order, I am wondering about an alternative use rear caliper while I sort the issue.
Knowing I would forgo the handbrake/e-brake, would then period (early 911 - 69 911T/912) "m" rear calipers work? I imagine the 912 or early 911T had solid rear rotors vs later vented (wider) rotors and calipers?) What are the piston size differences? How different is the mounting? Would I need a portioning valve installed or modified? Do they work with the stock rear rotor?
The car is otherwise very original, so I am not looking to upgrade everything brakes, just the rear calipers
I know the other answer is "reach out to PMB, they can help you"... and I will.. Just thought I'd ask here too.
TIA
914Sixer
post Aug 31 2020, 10:23 AM
Tangerine Racing has the rear brake kit to use 911 rear calipers. The short version for me is just fix the calipers.
- Lo-Fi Version Time is now: 17th July 2025 - 05:17 AM
