Scottish Reincarnation...., The start of my final build thread.... mk iii, Documenting the final build on to my repaired and repainted shell... |
RickS |
Feb 20 2020, 10:33 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Fascinating
wysri9 |
Aug 31 2020, 04:56 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
Finally had an opportunity to test wheels and tyres. Found a big difference left to right...... Right side would accept a 225/55/16, left would only accept a 205...... 205 rears and 195 fronts maybe not such a bad selection....? Any thoughts on rolling the left side to get more clearance for the 225????? I think I read on here somewhere that the stub axles must be installed and torqued before setting the car on its wheels and rolling. Can someone confirm that?? I have still to build the CV's and axles up..... Apologies for the rotated pictures again...... |
tazz9924 |
Aug 31 2020, 02:36 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Finally had an opportunity to test wheels and tyres. Found a big difference left to right...... Right side would accept a 225/55/16, left would only accept a 205...... 205 rears and 195 fronts maybe not such a bad selection....? Any thoughts on rolling the left side to get more clearance for the 225????? I think I read on here somewhere that the stub axles must be installed and torqued before setting the car on its wheels and rolling. Can someone confirm that?? I have still to build the CV's and axles up..... Apologies for the rotated pictures again...... It would certainly be good to torque the stub axle before setting it on the ground, it may even pull your hubs in a little bit so you can get that 205 under there. Id be worried about just setting it on the hubs and ruining the bearing. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:19 PM |
