| Highland |
Sep 3 2020, 02:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 560 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
The engine is a fresh rebuilt 2056 stock D-jet engine running Brad Penn 10W40. Once the oil gets warm the idiot light comes on and the oil pressure gauge (electrical VDO) goes to almost nothing.
Thinking about trying Tangerine's Oil pressure relief valve: http://www.tangerineracing.com/oilpressurerelief.htm Is it pretty easy to install with the engine in the car? Does it slide in easily or does it need to be pressed into the bore? The description says it bypasses the oil cooler so is the oil always going through the oil cooler even on cold start? One more note. I misplaced the engine's original plunger and spring assembly so I bought a used one. I have since found the original spring and plunger. Just wondering if anyone thinks putting the original part back in will fix the problem. The original engine was built as a 1.7 and I don't recall it having this problem. |
| crash914 |
Sep 3 2020, 05:16 PM
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
I use the tangerine valve. easy to install, just as easy as the spring and piston.
what is good is that it rides in a smooth bore with a tight fitting piston that will seal against an o-ring. Try the stock one and oil weight first. (its cheaper). it is a good product otherwise also. |
Highland Low Idle Oil Pressure Sep 3 2020, 02:00 PM
crash914 you should at least try the stock spring and pisto... Sep 3 2020, 02:13 PM
BillC The problem might be the oil weight. I think most... Sep 3 2020, 02:38 PM
barefoot Might try increasing the idle speed a touch, oll p... Sep 3 2020, 02:44 PM
porschetub
The engine is a fresh rebuilt 2056 stock D-jet en... Sep 3 2020, 02:49 PM
Highland Yes, new bearings all around and the crank was mea... Sep 3 2020, 04:25 PM
MichaelB Hi, another variable to consider is oil temp. Pres... Sep 3 2020, 05:15 PM
Highland So I thought I'd follow up in case anyone else... Oct 17 2020, 05:48 PM
Olympic 914 I did a rebuild on my engine and everything was in... Oct 17 2020, 06:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th October 2026 - 12:34 PM |
