> exhaust valve clearance keeps increasing
mightyohm
post Sep 6 2020, 06:10 PM
Hey all,
Long time, no posts.
I am having a hard time keeping the valves adjusted on my 914. I stopped driving the car a few years ago due to this issue, but have started working on it again. The clearance on #1 exhaust keeps increasing rapidly between adjustments. (The valve is getting looser and louder.) After a few hundred miles, the valve is making an awful racket. I just checked clearance today, and after about 1000 miles I had several times the specified 0.008" clearance (it could easily have been 0.050" or more - too big to measure). I adjusted the valve and I am running out of adjuster screw! See the attached pic. The other valves are fine.
Any idea what's going on here?
I pulled out the adjuster and it looks relatively fine - some flat spots from running with extreme clearance but it's not like the end is worn off.
I pulled the pushrod years ago and it seemed ok. But I should probably pull it again.
The car has solid lifters (I believe they are ceramic, installed years ago).
I would think that if I was dropping a valve seat, the valve would be tightening up vs. getting loose. But that could be what is going on. The car runs fine once I adjust the valve.
I would think that if the cam is losing a lobe, it would affect two opposed cylinders. Only #1 has this problem.
Any other ideas before I tear it apart?
Bleyseng
post Sep 7 2020, 08:44 AM
Aircooled Baby!
Order brand new heads from Len @ HAM now as your exhaust valve is recessing into the head. The chances are the seat will come loose and then you will spend the big bucks rebuilding the engine.
mightyohm   exhaust valve clearance keeps increasing   Sep 6 2020, 06:10 PM
Krieger   Do you ever check to see if the rocker arm hold do...   Sep 6 2020, 08:01 PM
mightyohm   Do you ever check to see if the rocker arm hold d...   Sep 7 2020, 09:26 AM
ClayPerrine   It sounds to me like you are starting to lose a va...   Sep 6 2020, 09:31 PM
914werke   :agree:   Sep 6 2020, 10:56 PM
Superhawk996   :agree: Valve seat is probably moving into towar...   Sep 7 2020, 07:21 AM
Bleyseng   Order brand new heads from Len @ HAM now as your e...   Sep 7 2020, 08:44 AM
mightyohm   Order brand new heads from Len @ HAM now as your ...   Sep 7 2020, 09:20 AM
Superhawk996   Order brand new heads from Len @ HAM now as your...   Sep 7 2020, 09:25 AM
mightyohm   If you're gaining clearance seat is not reces...   Sep 7 2020, 10:47 AM
Superhawk996   What are the chances a failed seat could be repa...   Sep 7 2020, 11:16 AM
Bleyseng   If you're gaining clearance seat is not rece...   Sep 8 2020, 12:13 PM
mightyohm   Order brand new heads from Len @ HAM now as your ...   Sep 7 2020, 10:06 AM
KSCarrera   The other thing to consider is that the pushrod is...   Sep 7 2020, 09:53 AM
yeahmag   I’d think loosing a cam lobe to be the most like...   Sep 7 2020, 10:25 AM
mightyohm   I’d think loosing a cam lobe to be the most lik...   Sep 7 2020, 10:27 AM
Superhawk996   Also take a close look at that spring retainer. C...   Sep 7 2020, 10:26 AM
mightyohm   Also take a close look at that spring retainer. ...   Sep 7 2020, 10:31 AM
Montreal914   You can contact Jorge at European Motorwerks in Ha...   Sep 7 2020, 01:15 PM
djway   A friend had a similar situation on a T1 rebuild. ...   Sep 8 2020, 03:27 AM
- Lo-Fi Version Time is now: 9th April 2026 - 03:44 PM
