> CV joints, Why they come off
Bartlett 914
post Sep 7 2020, 09:14 AM
I have experienced CV foints coming off my earlier car. This is an issue that many cars go through. I see threads on this topic from time to time. Most replies involve using new Schorr washers or wiring the bolt head. Some have used longer screws with jam nuts on the back side of the output flange. I do not see the actual cause being discussed and I would like to offer an explanation here.
What I have found is when the CV joint works loose. the stress on the bolts pulling on the output flange of the transmission distorts the flange. This results on a smaller contact surface between the CV and the flange. I corrected this using my lathe years ago an I have never had the work loose again. They worked loose in the past within a year.
Yesterday a local 914 member came over and we addressed his CV joint. One had come off. It did damage the the shift rod and caused considerable him grief. We replaced the shift console bushing and the shift rod. We then installed a replacement CV joint. I removed the output flange and put it in the lathe. Here are 3 shots. The first shows the condition before doing anything. You will see the flange surface is not clean. If it had been in full contact it would have looked better. The second shot shows a very slight clean up cut. Here you can see there is a 10 mm wide section where the flange cleaned up. Around all the bolt holes you can see a slight cleaning. What this means is no matter how tight you make the bolts that this is the only surface that will make contact! This results in allowing the CV to wiggle slightly under load. This leads to the screws backing out. So only a very small percentage of surface is making contact. For the correct results you need 100 percent contact between the two surfaces. The third shot is the final cleanup. I removed about .005" to get there. This metal is not real hard and cleans up easily..
If you do not have a lathe, then a flat surface and abrasive paper may work. Cutting a small countersink at each hole may also be helpful. You want to make certain that the threaded holes are hot high spots on the flange. New washers are advised.
Superhawk996
post Sep 7 2020, 09:37 AM
Nice job with clean up. (IMG:style_emoticons/default/piratenanner.gif)
As you state, the flange most likely was distorted by the wobble induced by a CV joint that has loosend and was driven with it loose.
However, proper torque and new Schnorr washers are mandatory.
When you get to root cause of the CV issues, it comes down to loss of clamp load. Way too many guys out there not using torque wrenches. A torque wrench is the price of entry to doing things properly and reliably.
Since you have a lathe, I'll assume that having a torque wrench is a no brainer. (IMG:style_emoticons/default/smile.gif)
Bartlett 914
post Sep 7 2020, 09:41 AM
QUOTE(Superhawk996 @ Sep 7 2020, 10:37 AM) *
When you get to root cause of the CV issues, it comes down to loss of clamp load. Way too many guys out there not using torque wrenches. A torque wrench is the price of entry to doing things properly.
I think you missed the point I was making. No matter how tight you make the bolts, the Joint will work loose. The gap created by the flange not being flat will allow movement between the surfaces, If there is no movement, then the bolts will not have any forces causing them to work loose!
Bartlett 914   CV joints   Sep 7 2020, 09:14 AM
Bartlett 914   Here is the finished flange   Sep 7 2020, 09:16 AM
ctc911ctc   Every new job is an opportunity to buy new tools...   Sep 7 2020, 09:34 AM
wndsrfr   Ummmm.....no mention of the use of the gasket in t...   Sep 7 2020, 07:20 PM
Spoke   Ummmm.....no mention of the use of the gasket in ...   Sep 8 2020, 07:10 AM
Bartlett 914   Ummmm.....no mention of the use of the gasket in...   Sep 8 2020, 07:52 AM
Bartlett 914   Ummmm.....no mention of the use of the gasket in ...   Sep 8 2020, 07:55 AM
Superhawk996   Nice job with clean up. :Qarl: As you state, t...   Sep 7 2020, 09:37 AM
Bartlett 914   Nice job with clean up. :Qarl: As you state, ...   Sep 7 2020, 09:41 AM
Superhawk996   Nice job with clean up. :Qarl: As you state,...   Sep 7 2020, 10:41 AM
Bartlett 914   [quote name='Bartlett 914' post='2849202' date='S...   Sep 7 2020, 10:47 AM
Superhawk996   [quote name='Superhawk996' post='2849212' date='S...   Sep 7 2020, 11:29 AM
914werke   not to throw fuel on the fire but to ignore the lo...   Sep 7 2020, 12:27 PM
R Dub   That's my output flange in the pictures and it...   Sep 7 2020, 02:10 PM
Bartlett 914   That's my output flange in the pictures. Just...   Sep 7 2020, 02:18 PM
R Dub   *duplicate*   Sep 7 2020, 02:10 PM
wysri9   All read and understood - very helpful. Further q...   Sep 7 2020, 03:12 PM
Bartlett 914   All read and understood - very helpful. Further ...   Sep 7 2020, 03:18 PM
wysri9   All read and understood - very helpful. Further...   Sep 8 2020, 02:11 AM
Porschef   This is very interesting; years ago when I swapped...   Sep 8 2020, 06:16 AM
Bartlett 914   This is very interesting; years ago when I swappe...   Sep 8 2020, 08:04 AM
brant   So my theory is that the gasket actually causes th...   Sep 8 2020, 06:29 AM
Porschef   Interesting. Thanks for the reply; I wonder how ma...   Sep 8 2020, 06:35 AM
- Lo-Fi Version Time is now: 9th April 2026 - 03:44 PM
