> exhaust valve clearance keeps increasing
mightyohm
post Sep 6 2020, 06:10 PM
Hey all,
Long time, no posts.
I am having a hard time keeping the valves adjusted on my 914. I stopped driving the car a few years ago due to this issue, but have started working on it again. The clearance on #1 exhaust keeps increasing rapidly between adjustments. (The valve is getting looser and louder.) After a few hundred miles, the valve is making an awful racket. I just checked clearance today, and after about 1000 miles I had several times the specified 0.008" clearance (it could easily have been 0.050" or more - too big to measure). I adjusted the valve and I am running out of adjuster screw! See the attached pic. The other valves are fine.
Any idea what's going on here?
I pulled out the adjuster and it looks relatively fine - some flat spots from running with extreme clearance but it's not like the end is worn off.
I pulled the pushrod years ago and it seemed ok. But I should probably pull it again.
The car has solid lifters (I believe they are ceramic, installed years ago).
I would think that if I was dropping a valve seat, the valve would be tightening up vs. getting loose. But that could be what is going on. The car runs fine once I adjust the valve.
I would think that if the cam is losing a lobe, it would affect two opposed cylinders. Only #1 has this problem.
Any other ideas before I tear it apart?
yeahmag
post Sep 7 2020, 10:25 AM
I’d think loosing a cam lobe to be the most likely. Pull the pushrod and use a magnet on a stick to pull the lifter and inspect.
mightyohm   exhaust valve clearance keeps increasing   Sep 6 2020, 06:10 PM
Krieger   Do you ever check to see if the rocker arm hold do...   Sep 6 2020, 08:01 PM
mightyohm   Do you ever check to see if the rocker arm hold d...   Sep 7 2020, 09:26 AM
ClayPerrine   It sounds to me like you are starting to lose a va...   Sep 6 2020, 09:31 PM
914werke   :agree:   Sep 6 2020, 10:56 PM
Superhawk996   :agree: Valve seat is probably moving into towar...   Sep 7 2020, 07:21 AM
Bleyseng   Order brand new heads from Len @ HAM now as your e...   Sep 7 2020, 08:44 AM
mightyohm   Order brand new heads from Len @ HAM now as your ...   Sep 7 2020, 09:20 AM
Superhawk996   Order brand new heads from Len @ HAM now as your...   Sep 7 2020, 09:25 AM
mightyohm   If you're gaining clearance seat is not reces...   Sep 7 2020, 10:47 AM
Superhawk996   What are the chances a failed seat could be repa...   Sep 7 2020, 11:16 AM
Bleyseng   If you're gaining clearance seat is not rece...   Sep 8 2020, 12:13 PM
mightyohm   Order brand new heads from Len @ HAM now as your ...   Sep 7 2020, 10:06 AM
KSCarrera   The other thing to consider is that the pushrod is...   Sep 7 2020, 09:53 AM
yeahmag   I’d think loosing a cam lobe to be the most like...   Sep 7 2020, 10:25 AM
mightyohm   I’d think loosing a cam lobe to be the most lik...   Sep 7 2020, 10:27 AM
Superhawk996   Also take a close look at that spring retainer. C...   Sep 7 2020, 10:26 AM
mightyohm   Also take a close look at that spring retainer. ...   Sep 7 2020, 10:31 AM
Montreal914   You can contact Jorge at European Motorwerks in Ha...   Sep 7 2020, 01:15 PM
djway   A friend had a similar situation on a T1 rebuild. ...   Sep 8 2020, 03:27 AM
- Lo-Fi Version Time is now: 9th April 2026 - 03:45 PM
