| mightyohm |
Sep 6 2020, 06:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Hey all,
Long time, no posts. I am having a hard time keeping the valves adjusted on my 914. I stopped driving the car a few years ago due to this issue, but have started working on it again. The clearance on #1 exhaust keeps increasing rapidly between adjustments. (The valve is getting looser and louder.) After a few hundred miles, the valve is making an awful racket. I just checked clearance today, and after about 1000 miles I had several times the specified 0.008" clearance (it could easily have been 0.050" or more - too big to measure). I adjusted the valve and I am running out of adjuster screw! See the attached pic. The other valves are fine. Any idea what's going on here? I pulled out the adjuster and it looks relatively fine - some flat spots from running with extreme clearance but it's not like the end is worn off. I pulled the pushrod years ago and it seemed ok. But I should probably pull it again. The car has solid lifters (I believe they are ceramic, installed years ago). I would think that if I was dropping a valve seat, the valve would be tightening up vs. getting loose. But that could be what is going on. The car runs fine once I adjust the valve. I would think that if the cam is losing a lobe, it would affect two opposed cylinders. Only #1 has this problem. Any other ideas before I tear it apart? Attached thumbnail(s) |
| Superhawk996 |
Sep 7 2020, 10:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,772 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Also take a close look at that spring retainer. Can't tell if that is some sort of casting / stamping flash or if you have cracking starting on the circumference of the retainer where it transitions into the keeper pocket. May just be the lighting of the photo but take a close look.
mightyohm exhaust valve clearance keeps increasing Sep 6 2020, 06:10 PM
Krieger Do you ever check to see if the rocker arm hold do... Sep 6 2020, 08:01 PM
mightyohm
Do you ever check to see if the rocker arm hold d... Sep 7 2020, 09:26 AM
ClayPerrine It sounds to me like you are starting to lose a va... Sep 6 2020, 09:31 PM
914werke :agree: Sep 6 2020, 10:56 PM
Superhawk996 :agree:
Valve seat is probably moving into towar... Sep 7 2020, 07:21 AM
Bleyseng Order brand new heads from Len @ HAM now as your e... Sep 7 2020, 08:44 AM
mightyohm
Order brand new heads from Len @ HAM now as your ... Sep 7 2020, 09:20 AM
Superhawk996
Order brand new heads from Len @ HAM now as your... Sep 7 2020, 09:25 AM
mightyohm
If you're gaining clearance seat is not reces... Sep 7 2020, 10:47 AM
Superhawk996
What are the chances a failed seat could be repa... Sep 7 2020, 11:16 AM
Bleyseng
If you're gaining clearance seat is not rece... Sep 8 2020, 12:13 PM
mightyohm
Order brand new heads from Len @ HAM now as your ... Sep 7 2020, 10:06 AM
KSCarrera The other thing to consider is that the pushrod is... Sep 7 2020, 09:53 AM
yeahmag I’d think loosing a cam lobe to be the most like... Sep 7 2020, 10:25 AM
mightyohm
I’d think loosing a cam lobe to be the most lik... Sep 7 2020, 10:27 AM
mightyohm
Also take a close look at that spring retainer. ... Sep 7 2020, 10:31 AM
Montreal914 You can contact Jorge at European Motorwerks in Ha... Sep 7 2020, 01:15 PM
djway A friend had a similar situation on a T1 rebuild. ... Sep 8 2020, 03:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 03:50 PM |
