Valve Train Geometry with Cam., Beating a dead horse. |
jaredmcginness |
Sep 8 2020, 01:14 PM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Hey guys,
Making headway on my 1911 build (no pun intended). I have a few valve train questions. I've researched this a good bit the last few days and read a couple informative threads on here with some info (including one by @nditiz1 that went through a very similar issue) I am trying to not over complicate this, so my tiny brain can make sense. I was having an issue with my rockers, posted a photo of my heads on the 914world facebook group and got a great response from J. Raby with a lot of helpful info. It seems I bit off a bit more than I can chew with valve train geometry. (I understand he wrote a dissertation about Valve Geometry a number of years ago, but I cannot seem to find it.) It does not surprise me that the fella/shop who built my bottom end didn't go into too much detail about this. He basically laid the numbers out and said "If I have X amount of cam lift, we need to machine the heads for dual springs to achieve X amount of clearance. All there is too it." Maybe there is a bit more involved than that. (IMG:style_emoticons/default/smile.gif) Specs: -1911 (96x66mm) -51cc heads - fresh. -Scat c35 .495 Lift -Scat solid lifters -Scat dual HD springs, head machined. Recommended additional purchases by Jake: All available at Type4Store -911 Swivel Foot / Machine rockers .060 -Solid Spacer and shims. Byebye rocker spring. -8mm HD studs for strength. Question: With all of this added, it seems like the heads will be much more sound, and be able to handle the possibly over-sized lift on the cam. -I have seemingly completed a proper valve adjustment using the "Lobe per lobe" technique. (I.E. Intake 3 fully open, adjust opposite rockers on 1) I cannot find a lot of info on the right way to do an adjustment with a large cam. Thoughts? My TDC mark on the flywheel doesn't match up with the valves due to the ramp of this cam. (I think I understand that right) -Does this geometry affect my pushrods? They SEEM to be working fine at their length. Do I need "chromoly"? Is this for strength and + cut to size? I read all these threads on the Samba of guys running large cams with stock rods. (probably my engine builder posting that stuff (IMG:style_emoticons/default/biggrin.gif)) I would just like to do this right the first time. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1599592477.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1599592477.2.jpg) Sounds like this motor is going to run like scat if I don't wrap my head around this and study a bit more. I'm really proud of what I have learned so far building this 914. But I am just at the tip of the iceberg. Feel free to just tell me to use the search function. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 02:23 AM |
