| Tdskip |
Sep 8 2020, 07:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Last engine swap I did I had access to a lift which made it easy. This next time I’m going to be “stuck “using jackstands to get the car in the air, and I’m wondering if this would be a good way of raising the engine/transmission to be mounted?
Assume the car should be as high up as safe and level? Thanks and hope it was a good long weekend. |
| mepstein |
Sep 8 2020, 10:44 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,625 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The shop where I used to work has used the HF lift tables for years for 911 engine and trans drops. They have six of them. None have ever failed. They just buy more because they are so useful. That’s about 600-700 lbs on a 3.6 with trans. I’m betting there is no difference in the hydraulic cylinder from harbor freight compared to any others. Use what you feel comfortable with but know that most of what differentiates different brands is only the name and the price.
The tangerine plate is excellent, but only works on a four cylinder. |
| thelogo |
Sep 8 2020, 11:45 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
The shop where I used to work has used the HF lift tables for years for 911 engine and trans drops. They have six of them. None have ever failed. They just buy more because they are so useful. That’s about 600-700 lbs on a 3.6 with trans. I’m betting there is no difference in the hydraulic cylinder from harbor freight compared to any others. Use what you feel comfortable with but know that most of what differentiates different brands is only the name and the price. The tangerine plate is excellent, but only works on a four cylinder. I get it but You know in the back of youre mind That its bound to fail (IMG:style_emoticons/default/sawzall-smiley.gif) Stop supporting and pumping money thru China.yeh its cheaper But can we be big picture guys ...or what Were our own worst enemy's ! (political content deleted - ADMIN) Rants over. Dead horse beaten |
| Front yard mechanic |
Sep 8 2020, 06:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,439 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
The shop where I used to work has used the HF lift tables for years for 911 engine and trans drops. They have six of them. None have ever failed. They just buy more because they are so useful. That’s about 600-700 lbs on a 3.6 with trans. I’m betting there is no difference in the hydraulic cylinder from harbor freight compared to any others. Use what you feel comfortable with but know that most of what differentiates different brands is only the name and the price. The tangerine plate is excellent, but only works on a four cylinder. I get it but You know in the back of youre mind That its bound to fail (IMG:style_emoticons/default/sawzall-smiley.gif) Stop supporting and pumping money thru China.yeh its cheaper But can we be big picture guys ...or what Were our own worst enemy's ! Rants over. Dead horse beaten |
| thelogo |
Sep 8 2020, 09:00 PM
The shop where I used to work has used the HF lift tables for years for 911 engine and trans drops. They have six of them. None have ever failed. They just buy more because they are so useful. That’s about 600-700 lbs on a 3.6 with trans. I’m betting there is no difference in the hydraulic cylinder from harbor freight compared to any others. Use what you feel comfortable with but know that most of what differentiates different brands is only the name and the price. The tangerine plate is excellent, but only works on a four cylinder. I get it but You know in the back of youre mind That its bound to fail (IMG:style_emoticons/default/sawzall-smiley.gif) Stop supporting and pumping money thru China.yeh its cheaper But can we be big picture guys ...or what Were our own worst enemy's ! Rants over. Dead horse beaten You are misinformed... Made in (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/pray.gif) JAPAN !!!! $$$ Big fuc#in difference ...huge Just like my 1st gen scion xb( jdm) !. That will run rings around suvs 10x its price. While getting 38mpg Those jdm engineers dont mess around Its a insult to compare em to made in china stufff . Go search around h.f. I guarantee you dont find 1 item made in japan... Rant over again . |
Tdskip Use this for a jackstand based engine install? Sep 8 2020, 07:41 AM
mepstein They work well for 911 instal and removals. Becaus... Sep 8 2020, 07:49 AM
Tdskip Thanks Mark, I already did and can’t imagine not... Sep 8 2020, 08:18 AM
johnhora Tdskip...
It has worked well for 914-6
I fixed the... Sep 8 2020, 08:25 AM
nditiz1 I literally just bought this two days ago so I can... Sep 8 2020, 08:55 AM
IronHillRestorations
I literally just bought this two days ago so I ca... Sep 8 2020, 07:09 PM
thelogo Sir Keith use's this and it works like a charm... Sep 8 2020, 09:32 AM
bdstone914 I have the Tangerine plate that you can borrow to ... Sep 8 2020, 09:43 AM
VaccaRabite Yeah I prefer the Tangerine plate. It also has a ... Sep 8 2020, 10:34 AM
gms Build a table with casters that will hold 2000ish ... Sep 8 2020, 11:02 AM
Tdskip
Build a table with casters that will hold 2000ish... Sep 8 2020, 04:40 PM
Build a table with casters that will hold 2000is... Sep 8 2020, 05:20 PM
ClayPerrine Since I have a lift, I put the car on the lift and... Sep 8 2020, 05:28 PM
ri914 there are some funny replies on this thread and so... Sep 8 2020, 07:12 PM
Gint Last engine swap I did I had access to a lift whic... Sep 8 2020, 07:30 PM
bkrantz I got one of these--very happy with it.
https://ww... Sep 8 2020, 07:39 PM
euro911 I got one of these--very happy with it.
[img]http:... Sep 10 2020, 01:58 AM
thelogo @thelogo - Unfortunately, we're hard-pressed ... Sep 10 2020, 07:39 AM
euro911 You talk about 0 American Pride - just what exactl... Sep 10 2020, 02:36 PM
thelogo X Sep 11 2020, 10:22 AM
Gint I like that larger platform on the lift cart. Con... Sep 8 2020, 07:41 PM
AmjadY I used that same cart for my boxster engine/trans.... Sep 8 2020, 09:08 PM
Gint I used that same cart for my boxster engine/trans.... Sep 8 2020, 09:36 PM
rgalla9146 The OP wants to install his 6 engine on the floor ... Sep 9 2020, 10:51 AM
Gint If I were to do it using jackstands, I'd remov... Sep 9 2020, 11:27 AM
Steve I also used the 1000 pound table to remove and ins... Sep 9 2020, 11:00 PM
Tdskip Great discussion gentlemen. This is actually a Typ... Sep 10 2020, 06:15 AM
mepstein There was a good point made earlier in the thread.... Sep 10 2020, 03:19 PM
Gint There was a good point made earlier in the thread.... Sep 15 2020, 08:06 AM
euro911 They're both invaluable when utilized with a l... Sep 10 2020, 03:29 PM
Tdskip @mepstein - excellent consideration and thank yo... Sep 10 2020, 04:56 PM
VaccaRabite
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 11 2020, 08:36 AM
Tdskip @thelogo - appreciate the thoughts but let’s st... Sep 11 2020, 10:27 AM
euro911 Egads - he's all over the place :screwy: Sep 11 2020, 10:50 AM
mlindner This subject is just in time. With the scissors li... Sep 13 2020, 07:44 AM
Tdskip Let us know how it goes Mark Sep 13 2020, 07:51 AM
rhodyguy Rear tires and carbs off. Take the carbs off as a ... Sep 13 2020, 08:51 AM
sixnotfour For 911's I use the factory jack plate , it ti... Sep 13 2020, 09:28 AM
Tdskip Good tips, thanks. Sep 13 2020, 11:53 AM
Mark Henry I have a lift table, 660lbs, same as the HF table ... Sep 15 2020, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th April 2026 - 06:02 AM |
