| Tdskip |
Sep 8 2020, 07:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Last engine swap I did I had access to a lift which made it easy. This next time I’m going to be “stuck “using jackstands to get the car in the air, and I’m wondering if this would be a good way of raising the engine/transmission to be mounted?
Assume the car should be as high up as safe and level? Thanks and hope it was a good long weekend. |
| AmjadY |
Sep 8 2020, 09:08 PM
Newbie ![]() Group: Members Posts: 29 Joined: 22-September 13 From: Detroit Member No.: 16,417 Region Association: Upper MidWest |
I used that same cart for my boxster engine/trans. Worked great
| Gint |
Sep 8 2020, 09:36 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I used that same cart for my boxster engine/trans. Worked great (IMG:style_emoticons/default/thumb3d.gif) |
Tdskip Use this for a jackstand based engine install? Sep 8 2020, 07:41 AM
mepstein They work well for 911 instal and removals. Becaus... Sep 8 2020, 07:49 AM
Tdskip Thanks Mark, I already did and can’t imagine not... Sep 8 2020, 08:18 AM
johnhora Tdskip...
It has worked well for 914-6
I fixed the... Sep 8 2020, 08:25 AM
nditiz1 I literally just bought this two days ago so I can... Sep 8 2020, 08:55 AM
IronHillRestorations
I literally just bought this two days ago so I ca... Sep 8 2020, 07:09 PM
thelogo Sir Keith use's this and it works like a charm... Sep 8 2020, 09:32 AM
bdstone914 I have the Tangerine plate that you can borrow to ... Sep 8 2020, 09:43 AM
VaccaRabite Yeah I prefer the Tangerine plate. It also has a ... Sep 8 2020, 10:34 AM
mepstein The shop where I used to work has used the HF lift... Sep 8 2020, 10:44 AM
thelogo
The shop where I used to work has used the HF lif... Sep 8 2020, 11:45 AM
Front yard mechanic
The shop where I used to work has used the HF li... Sep 8 2020, 06:38 PM
thelogo
[quote name='thelogo' post='2849474' date='Sep 8 ... Sep 8 2020, 09:00 PM
gms Build a table with casters that will hold 2000ish ... Sep 8 2020, 11:02 AM
Tdskip
Build a table with casters that will hold 2000ish... Sep 8 2020, 04:40 PM
Build a table with casters that will hold 2000is... Sep 8 2020, 05:20 PM
ClayPerrine Since I have a lift, I put the car on the lift and... Sep 8 2020, 05:28 PM
ri914 there are some funny replies on this thread and so... Sep 8 2020, 07:12 PM
Gint Last engine swap I did I had access to a lift whic... Sep 8 2020, 07:30 PM
bkrantz I got one of these--very happy with it.
https://ww... Sep 8 2020, 07:39 PM
euro911 I got one of these--very happy with it.
[img]http:... Sep 10 2020, 01:58 AM
thelogo @thelogo - Unfortunately, we're hard-pressed ... Sep 10 2020, 07:39 AM
euro911 You talk about 0 American Pride - just what exactl... Sep 10 2020, 02:36 PM
thelogo X Sep 11 2020, 10:22 AM
Gint I like that larger platform on the lift cart. Con... Sep 8 2020, 07:41 PM
rgalla9146 The OP wants to install his 6 engine on the floor ... Sep 9 2020, 10:51 AM
Gint If I were to do it using jackstands, I'd remov... Sep 9 2020, 11:27 AM
Steve I also used the 1000 pound table to remove and ins... Sep 9 2020, 11:00 PM
Tdskip Great discussion gentlemen. This is actually a Typ... Sep 10 2020, 06:15 AM
mepstein There was a good point made earlier in the thread.... Sep 10 2020, 03:19 PM
Gint There was a good point made earlier in the thread.... Sep 15 2020, 08:06 AM
euro911 They're both invaluable when utilized with a l... Sep 10 2020, 03:29 PM
Tdskip @mepstein - excellent consideration and thank yo... Sep 10 2020, 04:56 PM
VaccaRabite
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 11 2020, 08:36 AM
Tdskip @thelogo - appreciate the thoughts but let’s st... Sep 11 2020, 10:27 AM
euro911 Egads - he's all over the place :screwy: Sep 11 2020, 10:50 AM
mlindner This subject is just in time. With the scissors li... Sep 13 2020, 07:44 AM
Tdskip Let us know how it goes Mark Sep 13 2020, 07:51 AM
rhodyguy Rear tires and carbs off. Take the carbs off as a ... Sep 13 2020, 08:51 AM
sixnotfour For 911's I use the factory jack plate , it ti... Sep 13 2020, 09:28 AM
Tdskip Good tips, thanks. Sep 13 2020, 11:53 AM
Mark Henry I have a lift table, 660lbs, same as the HF table ... Sep 15 2020, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th April 2026 - 06:00 AM |
