> Use this for a jackstand based engine install?
Tdskip
post Sep 8 2020, 07:41 AM
Last engine swap I did I had access to a lift which made it easy. This next time I’m going to be “stuck “using jackstands to get the car in the air, and I’m wondering if this would be a good way of raising the engine/transmission to be mounted?
Assume the car should be as high up as safe and level?
Thanks and hope it was a good long weekend.
Steve
post Sep 9 2020, 11:00 PM
I also used the 1000 pound table to remove and install my 3.2 and 915 trans. The 500 pound table couldn’t handle the weight, but the 1000 pound table worked great with my scissor lift. Only issue is the 3.2 is not flat on the bottom so it kept teeter tottering on the table. I used wooden blocks to keep it from rocking.
Tdskip   Use this for a jackstand based engine install?   Sep 8 2020, 07:41 AM
mepstein   They work well for 911 instal and removals. Becaus...   Sep 8 2020, 07:49 AM
Tdskip   Thanks Mark, I already did and can’t imagine not...   Sep 8 2020, 08:18 AM
johnhora   Tdskip... It has worked well for 914-6 I fixed the...   Sep 8 2020, 08:25 AM
nditiz1   I literally just bought this two days ago so I can...   Sep 8 2020, 08:55 AM
IronHillRestorations   I literally just bought this two days ago so I ca...   Sep 8 2020, 07:09 PM
thelogo   Sir Keith use's this and it works like a charm...   Sep 8 2020, 09:32 AM
bdstone914   I have the Tangerine plate that you can borrow to ...   Sep 8 2020, 09:43 AM
VaccaRabite   Yeah I prefer the Tangerine plate. It also has a ...   Sep 8 2020, 10:34 AM
mepstein   The shop where I used to work has used the HF lift...   Sep 8 2020, 10:44 AM
thelogo   The shop where I used to work has used the HF lif...   Sep 8 2020, 11:45 AM
Front yard mechanic   The shop where I used to work has used the HF li...   Sep 8 2020, 06:38 PM
thelogo   [quote name='thelogo' post='2849474' date='Sep 8 ...   Sep 8 2020, 09:00 PM
gms   Build a table with casters that will hold 2000ish ...   Sep 8 2020, 11:02 AM
Tdskip   Build a table with casters that will hold 2000ish...   Sep 8 2020, 04:40 PM
mepstein   Build a table with casters that will hold 2000is...   Sep 8 2020, 05:20 PM
ClayPerrine   Since I have a lift, I put the car on the lift and...   Sep 8 2020, 05:28 PM
ri914   there are some funny replies on this thread and so...   Sep 8 2020, 07:12 PM
Gint   Last engine swap I did I had access to a lift whic...   Sep 8 2020, 07:30 PM
bkrantz   I got one of these--very happy with it. https://ww...   Sep 8 2020, 07:39 PM
euro911   I got one of these--very happy with it. [img]http:...   Sep 10 2020, 01:58 AM
thelogo   @thelogo - Unfortunately, we're hard-pressed ...   Sep 10 2020, 07:39 AM
euro911   You talk about 0 American Pride - just what exactl...   Sep 10 2020, 02:36 PM
thelogo   X   Sep 11 2020, 10:22 AM
Gint   I like that larger platform on the lift cart. Con...   Sep 8 2020, 07:41 PM
AmjadY   I used that same cart for my boxster engine/trans....   Sep 8 2020, 09:08 PM
Gint   I used that same cart for my boxster engine/trans....   Sep 8 2020, 09:36 PM
rgalla9146   The OP wants to install his 6 engine on the floor ...   Sep 9 2020, 10:51 AM
Gint   If I were to do it using jackstands, I'd remov...   Sep 9 2020, 11:27 AM
Steve   I also used the 1000 pound table to remove and ins...   Sep 9 2020, 11:00 PM
Tdskip   Great discussion gentlemen. This is actually a Typ...   Sep 10 2020, 06:15 AM
mepstein   There was a good point made earlier in the thread....   Sep 10 2020, 03:19 PM
Gint   There was a good point made earlier in the thread....   Sep 15 2020, 08:06 AM
euro911   They're both invaluable when utilized with a l...   Sep 10 2020, 03:29 PM
Tdskip   @mepstein - excellent consideration and thank yo...   Sep 10 2020, 04:56 PM
VaccaRabite   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 11 2020, 08:36 AM
Tdskip   @thelogo - appreciate the thoughts but let’s st...   Sep 11 2020, 10:27 AM
euro911   Egads - he's all over the place :screwy:   Sep 11 2020, 10:50 AM
mlindner   This subject is just in time. With the scissors li...   Sep 13 2020, 07:44 AM
Tdskip   Let us know how it goes Mark   Sep 13 2020, 07:51 AM
rhodyguy   Rear tires and carbs off. Take the carbs off as a ...   Sep 13 2020, 08:51 AM
sixnotfour   For 911's I use the factory jack plate , it ti...   Sep 13 2020, 09:28 AM
Tdskip   Good tips, thanks.   Sep 13 2020, 11:53 AM
Mark Henry   I have a lift table, 660lbs, same as the HF table ...   Sep 15 2020, 08:50 AM
- Lo-Fi Version Time is now: 13th April 2026 - 06:01 AM
