> Use this for a jackstand based engine install?
Tdskip
post Sep 8 2020, 07:41 AM
Last engine swap I did I had access to a lift which made it easy. This next time I’m going to be “stuck “using jackstands to get the car in the air, and I’m wondering if this would be a good way of raising the engine/transmission to be mounted?
Assume the car should be as high up as safe and level?
Thanks and hope it was a good long weekend.
Tdskip
post Sep 10 2020, 06:15 AM
Great discussion gentlemen. This is actually a Type 4 going in this one, not quite ready for the six swap.
Tdskip   Use this for a jackstand based engine install?   Sep 8 2020, 07:41 AM
mepstein   They work well for 911 instal and removals. Becaus...   Sep 8 2020, 07:49 AM
Tdskip   Thanks Mark, I already did and can’t imagine not...   Sep 8 2020, 08:18 AM
johnhora   Tdskip... It has worked well for 914-6 I fixed the...   Sep 8 2020, 08:25 AM
nditiz1   I literally just bought this two days ago so I can...   Sep 8 2020, 08:55 AM
IronHillRestorations   I literally just bought this two days ago so I ca...   Sep 8 2020, 07:09 PM
thelogo   Sir Keith use's this and it works like a charm...   Sep 8 2020, 09:32 AM
bdstone914   I have the Tangerine plate that you can borrow to ...   Sep 8 2020, 09:43 AM
VaccaRabite   Yeah I prefer the Tangerine plate. It also has a ...   Sep 8 2020, 10:34 AM
mepstein   The shop where I used to work has used the HF lift...   Sep 8 2020, 10:44 AM
thelogo   The shop where I used to work has used the HF lif...   Sep 8 2020, 11:45 AM
Front yard mechanic   The shop where I used to work has used the HF li...   Sep 8 2020, 06:38 PM
thelogo   [quote name='thelogo' post='2849474' date='Sep 8 ...   Sep 8 2020, 09:00 PM
gms   Build a table with casters that will hold 2000ish ...   Sep 8 2020, 11:02 AM
Tdskip   Build a table with casters that will hold 2000ish...   Sep 8 2020, 04:40 PM
mepstein   Build a table with casters that will hold 2000is...   Sep 8 2020, 05:20 PM
ClayPerrine   Since I have a lift, I put the car on the lift and...   Sep 8 2020, 05:28 PM
ri914   there are some funny replies on this thread and so...   Sep 8 2020, 07:12 PM
Gint   Last engine swap I did I had access to a lift whic...   Sep 8 2020, 07:30 PM
bkrantz   I got one of these--very happy with it. https://ww...   Sep 8 2020, 07:39 PM
euro911   I got one of these--very happy with it. [img]http:...   Sep 10 2020, 01:58 AM
thelogo   @thelogo - Unfortunately, we're hard-pressed ...   Sep 10 2020, 07:39 AM
euro911   You talk about 0 American Pride - just what exactl...   Sep 10 2020, 02:36 PM
thelogo   X   Sep 11 2020, 10:22 AM
Gint   I like that larger platform on the lift cart. Con...   Sep 8 2020, 07:41 PM
AmjadY   I used that same cart for my boxster engine/trans....   Sep 8 2020, 09:08 PM
Gint   I used that same cart for my boxster engine/trans....   Sep 8 2020, 09:36 PM
rgalla9146   The OP wants to install his 6 engine on the floor ...   Sep 9 2020, 10:51 AM
Gint   If I were to do it using jackstands, I'd remov...   Sep 9 2020, 11:27 AM
Steve   I also used the 1000 pound table to remove and ins...   Sep 9 2020, 11:00 PM
Tdskip   Great discussion gentlemen. This is actually a Typ...   Sep 10 2020, 06:15 AM
mepstein   There was a good point made earlier in the thread....   Sep 10 2020, 03:19 PM
Gint   There was a good point made earlier in the thread....   Sep 15 2020, 08:06 AM
euro911   They're both invaluable when utilized with a l...   Sep 10 2020, 03:29 PM
Tdskip   @mepstein - excellent consideration and thank yo...   Sep 10 2020, 04:56 PM
VaccaRabite   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 11 2020, 08:36 AM
Tdskip   @thelogo - appreciate the thoughts but let’s st...   Sep 11 2020, 10:27 AM
euro911   Egads - he's all over the place :screwy:   Sep 11 2020, 10:50 AM
mlindner   This subject is just in time. With the scissors li...   Sep 13 2020, 07:44 AM
Tdskip   Let us know how it goes Mark   Sep 13 2020, 07:51 AM
rhodyguy   Rear tires and carbs off. Take the carbs off as a ...   Sep 13 2020, 08:51 AM
sixnotfour   For 911's I use the factory jack plate , it ti...   Sep 13 2020, 09:28 AM
Tdskip   Good tips, thanks.   Sep 13 2020, 11:53 AM
Mark Henry   I have a lift table, 660lbs, same as the HF table ...   Sep 15 2020, 08:50 AM
- Lo-Fi Version Time is now: 13th April 2026 - 06:01 AM
