> Anyone running 9:1 or higher on the street?
-JR-
post Dec 19 2004, 02:55 PM
Life goes faster at 150MPH
I'm still hashing over compression ratios. I've been reading online that these motors don't or won't run compressions as high as 9:1 without taking extra steps. Like aluminum cylinders or electronic fuel injection. Mainly just because of the heat involved.
Has anyone "got away" with running higher compressions like this on stock cylinders?
*** IF anyone has any feedback on what fuel grade they are running at their higher compression and if they are getting any knocks ect... I would also greatly appreciate that information too.
Thanks everyone!
James
Brett W
post Dec 19 2004, 11:02 PM
AAAAHHHH the urban legend is back. Compression does not equate heat. The problem with running very low compression ratio is that it is very inefficient. All of the fuel air mixture does not burn inside the cylinder where it makes the most power. Some of that unburned mixture escapes from the cylinder and continues to burn on its way out the exhaust. This is what raises the head temps. If you run higher compression ratios then more of the mixture is burned inside the cylinder. Power is made through heat. The more heat you can keep inside the combustion chamber the more efficient the engine will be.
Higher compression = better fuel mileage, better throttle response, more power
Low Compression = Poor gas mileage, poor engine efficiency
With a higher compression ratio and proper camshaft design you can run much higher compression. Your car will be much more fun to drive.
This is one take on the situation.
http://www.theoldone.com/articles/The%5FSo...%5FHead%5F1999/
I ran 8.9:1 on 89 octane without any problems. My engine ran better on 89 than 93. I am building a 2056 right now that has 9.5:1, should have no problems running on 89.
-JR-   Anyone running 9:1 or higher on the street?   Dec 19 2004, 02:55 PM
spare time toys   I have like 19 to 1 buts its in a TDI :D   Dec 19 2004, 03:20 PM
skline   I am running about 11 to 1 in mine. Very responsiv...   Dec 19 2004, 03:23 PM
cha914   Mine is 8.8 to 1 and I run premium (93 around here...   Dec 19 2004, 03:55 PM
SirAndy   9:1 on a 2056 with no special cyl. or heads ... 9...   Dec 19 2004, 03:58 PM
Aaron Cox   euro pistons get me what? 9 ish to 1? i run 89.......   Dec 19 2004, 04:01 PM
Bleyseng   Euro's are 8to1 Aaron..... I am running 8.2to...   Dec 19 2004, 05:30 PM
Brett W   AAAAHHHH the urban legend is back. Compression do...   Dec 19 2004, 11:02 PM
Brando   Also a friend of mine in the petro-chemicals indus...   Dec 19 2004, 11:16 PM
Brett W   Higher octane does indeed burn slower. More timin...   Dec 20 2004, 12:04 AM
Jake Raby   In my testing and experience I have seen that inad...   Dec 20 2004, 11:08 AM
Bleyseng   but isn't that what VW/Porsche wanted to do in...   Dec 20 2004, 11:27 AM
Jake Raby   While melting the heads and dropping seats.... Th...   Dec 20 2004, 12:37 PM
Red-Beard   CO gets better, but NOx goes up, way up, with flam...   Dec 20 2004, 12:47 PM
lapuwali     Dec 20 2004, 02:01 PM
Jake Raby   I have had 10:1 2270s pass emission tests in CA an...   Dec 20 2004, 02:04 PM
lapuwali
  Dec 20 2004, 02:19 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 02:20 PM
