| The Double S |
Sep 13 2020, 09:09 AM
Member ![]() ![]() Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California |
A lot of older threads on the topic of marrying transaxles to V8s. I just finished rebuilding an LS1 and am looking to weigh current and cost effective options on the trans. G50s are out of my league but Boxter and Subaru variants sound efficient and reliable. Currently running a SBC 350 and 901 side shift.
For those of you who have had the experience of building them, or are building them now, what are your opinions, preferences, or realizations? Planning for a street/track set up. Thank you for the help in advance. |
| tygaboy |
Sep 13 2020, 02:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,864 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
To your point, it's about budget. I have an LS3 and I didn't want to worry about things breaking so I went with a Boxster S 6-speed (G86-20) as they've been proven to about 500 hp.
They can be found on ebay in the $2k range. You can get a stock shifter and cables for a couple hundred, last I looked. Kennedy Engineering makes the adapter plate, flywheel and clutch. Or you can get the whole kit, including trans mounts from Renegade, but it's not cheap. Best of luck with your decision. |
| horizontally-opposed |
Sep 13 2020, 03:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
To your point, it's about budget. I have an LS3 and I didn't want to worry about things breaking so I went with a Boxster S 6-speed (G86-20) as they've been proven to about 500 hp. They can be found on ebay in the $2k range. You can get a stock shifter and cables for a couple hundred, last I looked. Kennedy Engineering makes the adapter plate, flywheel and clutch. Or you can get the whole kit, including trans mounts from Renegade, but it's not cheap. Best of luck with your decision. Chris, is the proven to about 500 hp with V8s or flat sixes or? Curious as the later 981 GT4 6MT signed off on by Motorsport was limited to 310 lb-ft, which arrives at 4700+ rpm in that car. The gearing is pretty bad in a 981, too, with 2nd stretching to 84 mph and 3rd to 112 mph—so not too fun on a back road. I've started to wonder about taking a 7MT from a 991 and flipping the ring gear as people do with 915 gearboxes, as the torque limit is higher. Next question is whether there's a way to delete 7th gear or lock it out like Porsche does on the GT4 Clubsport PDK, or just enjoy 9,000,000 miles per gallon. |
The Double S LS1 Guys: Best, Recent Transaxle Options? Sep 13 2020, 09:09 AM
tygaboy
[quote name='tygaboy' post='2850932' date='Sep 13... Sep 13 2020, 05:01 PM
Pete - I was only concerned about what to use wi... Sep 13 2020, 06:47 PM
djway
[quote name='tygaboy' post='2850932' date='Sep 1... Sep 13 2020, 11:31 PM
The Double S
To your point, it's about budget. I have an L... Sep 13 2020, 04:37 PM
tygaboy
To your point, it's about budget. I have an ... Sep 13 2020, 05:11 PM
Army Roger Same set up I'm starting with on my new 914 pr... Sep 15 2020, 02:05 PM
Same set up I'm starting with on my new 914 p... Sep 15 2020, 02:40 PM
ri914 I chose an LS6 with the renegade kit. super happy ... Sep 13 2020, 07:13 PM
I chose an LS6 with the renegade kit. super happy... Sep 13 2020, 08:37 PM
ri914
I'd have to dig into 986 gearing, but 981 g... Sep 14 2020, 06:00 AM
dwillouby I have an 04 Boxster s 6 speed behind my LS2.
Use... Sep 14 2020, 11:15 AM
The Double S
Us... Sep 15 2020, 01:35 PM
Mueller If money was no object..Xtrac transmission.
Guess... Sep 14 2020, 12:21 PM
cali914
Gues... Sep 14 2020, 03:50 PM
djway Several mentions that the KEP adapter and Renegade... Sep 15 2020, 05:51 PM
tygaboy http://www.renegadehybrids.com/ Sep 15 2020, 06:50 PM
The Double S
I've review... Sep 16 2020, 10:01 AM
Gearup I have an LS1 and Boxster S. Go with Stuttgart Mu... Sep 15 2020, 06:58 PM
The Double S
I have an LS1 and Boxster S. Go with Stuttgart M... Sep 16 2020, 10:08 AM
dwillouby You can buy the parts from Kennedy.
Renegade just... Sep 16 2020, 11:32 AM
The Double S
Renegade jus... Sep 16 2020, 12:15 PM
Mueller
Renegade ju... Sep 16 2020, 03:05 PM
dwillouby Renegade has the mounts made for them.
Their mou... Sep 16 2020, 03:24 PM
The Double S
Their mo... Sep 17 2020, 06:31 AM
tygaboy Axles will depend on what you do at the hub. If yo... Sep 17 2020, 08:13 AM
tygaboy @The Double S - You should make the trip up for t... Sep 17 2020, 08:20 AM
The Double S
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 18 2020, 06:58 AM
dwillouby With my setup I am using the early 911 cv's ... Sep 17 2020, 11:36 AM
The Double S As I have been researching this over the past year... Sep 18 2020, 01:58 PM
Mueller
As I have been researching this over the past yea... Sep 18 2020, 02:13 PM
The Double S I appreciate everyone's input. A lot of great ... Sep 29 2020, 01:39 PM
burton73
I appreciate everyone's input. A lot of great... Oct 2 2020, 01:59 PM
Mueller
I appreciate everyone's input. A lot of great... Oct 2 2020, 02:36 PM
burton73
I appreciate everyone's input. A lot of grea... Oct 2 2020, 02:56 PM
The Double S
I appreciate everyone's input. A lot of grea... Oct 6 2020, 12:05 AM
Mueller
[quote name='Mueller' post='2856159' date='Oct 2 ... Oct 6 2020, 11:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th November 2026 - 08:51 AM |
