| Stltri |
Sep 15 2020, 04:28 PM
Member ![]() ![]() Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
Been trying to track down a clunk from the driver front end. Car is a 74 with Koni adjustable insert/shocks on all 4 corners. Looks like its coming from the shock on driver side at the top. Something is loose inside the shock tube and/or cover which duplicates what I hear/feel while driving. I checked everything else on the arms/rack/torsion bars/ball joint and everything tight (since I just also recently replaced all bushings etc). So I wanted to remove the shock to take a look but could not remove the nut after loosening it (while countering with a pipe wrench). I suspect the tab washer (which usually locks the nut and prevent it from spinning) broke. I have read that maybe a impact wrench (I have a cordless and corded impact but not air impact wrench) may spin it loose but may also damage the shock internals so I have not tried that route? Any other ideas on how to remove the nut?
| mepstein |
Sep 15 2020, 05:24 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,017 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I use an impact wrench to remove. Takes two seconds and no shock damage. I was told to do it that way by a long time Porsche tech.
It’s not on super tight so any cordless should work fine. Clunks are usually from the large strut top nut under the large dust cap/metal cylinder coming loose. A pipe wrench will tighten it down. |
| ClayPerrine |
Sep 16 2020, 01:00 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Clunks are usually from the large strut top nut under the large dust cap/metal cylinder coming loose. A pipe wrench will tighten it down. (IMG:style_emoticons/default/agree.gif) I had this happen on two different 914s. Put a small dab of locktite red on the threads of the strut top nut when reassembling. Clay |
| Stltri |
Sep 16 2020, 05:17 PM
Clunks are usually from the large strut top nut under the large dust cap/metal cylinder coming loose. A pipe wrench will tighten it down. (IMG:style_emoticons/default/agree.gif) I had this happen on two different 914s. Put a small dab of locktite red on the threads of the strut top nut when reassembling. Clay You both are correct. I got the rod down enough to peek at the gland nut under cap which is indeed loose and probably causing the clunk. However something is binding the shock rod to come down further. I may have to either remove the top strut mount and redo my alignment later or free up the arms from below. Any other ideas? |
Stltri help with removing front shock top nut (Koni) Sep 15 2020, 04:28 PM
bdstone914 Grip the dished washer below the nut with some sli... Sep 15 2020, 04:46 PM
Stltri
Grip the dished washer below the nut with some sl... Sep 15 2020, 05:17 PM
porschetub Bruce nailed it :trophy: ,most likely the locking... Sep 15 2020, 05:21 PM
Stltri
I use an impact wrench to remove. Takes two secon... Sep 15 2020, 06:23 PM
Stltri
[quote name='mepstein' post='2851623' date='Sep 1... Sep 16 2020, 12:55 PM
bdstone914 @Stltri
You do have the wheel off the ground cor... Sep 16 2020, 05:52 PM
Stltri
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 16 2020, 07:05 PM
mepstein Lube the rod where it passes through the rubber.
... Sep 16 2020, 05:32 PM
Stltri
Lube the rod where it passes through the rubber. ... Sep 16 2020, 07:04 PM
rhodyguy Have you pulled the shaft free of the bushing? Pul... Sep 16 2020, 09:52 PM
Stltri
Have you pulled the shaft free of the bushing? Pu... Sep 17 2020, 01:52 PM
mepstein There’s a 2-3mm gap with bilstein inserts so the... Sep 17 2020, 03:18 PM
Stltri
There’s a 2-3mm gap with bilstein inserts so th... Sep 17 2020, 05:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 10:00 AM |
